It is currently Tue Nov 03, 2026 7:30 pm
Post Posted: Fri May 04, 2012 9:21 pm
Got two LWB Vitara tanks here, the ones with swimmer pump, perfect for that EFI conversion.
One tank is dinted but the other is in excellent condition.
These tanks WILL fit in a Sierra but you will need to modify the rear mounts and move the shock towers forward a little (this gives you the opportunity for inboard shock mounts for those longer travel shocks, at least that's what I did anyway).
They are in Hampton Park, $200 (now $150) for both with pump.
Post Posted: Fri May 04, 2012 9:30 pm
Do you know if they are 55 or 70 Litre tanks ?
Post Posted: Fri May 04, 2012 9:48 pm
They wont be 70L tanks, because they don't fit between the chassis rails of a sierra.
Post Posted: Fri May 04, 2012 9:53 pm
Bummer. Thanks. Was worth a shot.
Post Posted: Fri May 04, 2012 11:43 pm
They are the 70ish litre tanks, they do fit between the rails up to the centre flange.
Post Posted: Sat May 05, 2012 6:58 am
which vitaras had 70ltr tanks?
Post Posted: Sat May 05, 2012 9:19 am
The long wheel base ones. Originally when I fitted it to my sierra I remember thinking that it was more involved than what I had read, but went ahead, modified and fitted it anyway thinking that it was a SWB tank. Its a big suprise when the fuel bowser spins past 30litres and doesn't click off like I was used to.
Hmm Shep you have me doubting myself on how much capacity it had, maybe it was 55, can't remember. Either way, its the LWB tank.
Post Posted: Sat May 05, 2012 11:03 am
70 would be awesome. I am sticking a lwb tank in my Sierra and also keeping the original tank so 110ltr would be great
Post Posted: Sun May 06, 2012 9:01 pm
I want 70L!!! Must be the 2L onwards. My 1.6 (LWB EFI) tank is 45L tops.
Anyone know if it could be made to work?
Post Posted: Sun May 06, 2012 10:31 pm
No.
They aren't.
The LWB 1.6 vitara has a 55L tank. THEY fit in a sierra...JUST.
The 70L tank from the SV series vitaras are over 750 wide, not including the mounting flanges. A sierra chassis is 695/700 wide.
If you had one in yor sierra it must have been the 55L from a 1.6 vitara LWB.
Post Posted: Sun May 06, 2012 10:32 pm
Yes, but you will have nowhere between the chassis rails to route your exhaust past the fuel tank. It would have to side exit before the tank......
Post Posted: Sun May 06, 2012 10:47 pm
Yeh thats what I had to do, I routed the exhaust out the drivers side before the rear wheel. Was good having a decent range.
Post Posted: Sun May 06, 2012 11:06 pm
What about fitting it sideways in a lwb?
Post Posted: Sun May 06, 2012 11:21 pm
You need 800mm. If you have the space infront or behind the axle for that, then yes it would fit. Allthough I doubt you do.
Post Posted: Sun May 06, 2012 11:32 pm
Actually I just went and measure the ute. The rear axle is moved back 80mm.
I have 500mm between the back of the diff housing and the rear cross member.
I have 900mm between the back of the transfer and the front of the rear housing, BUT the tank would be wide enough that it would sit over the top of the rear driveshaft. So if you intend to keep the floor in your LWB, the tank would have to be mounted very low. Low enough that you would have zero uptravel in the rear before the driveshaft took out the tank.
Post Posted: Mon May 07, 2012 12:08 am
I can live with that. Going to need some exhaust work now anyway...
If the 1.6 LWB are a 55L tank the fuel guage must be incredibly pessimistic - I've had it well below "E" and never put more than about 46L in.
Post Posted: Mon May 07, 2012 12:29 am
1.6 8v >>>>> 42L
1.6 16v >>>> 42L
1.6 LWB >>>> 55L
SV 2.0L (LWB & SWB) >>>>> 70L ( most I can fit is 60L. But I have never run it out...)
Post Posted: Mon May 07, 2012 7:04 am
do ya mean the rear cross member or the one the stock tank bolts to? i reckon there is room for another stock tank behind the original stock tank.
admittedly it has been a while since i have had a look under it, might stick it on my hoist today for a look.
Post Posted: Mon May 07, 2012 12:34 pm
I should have been clearer Shep.
I have removed/ replaced all factory cross members on my chassis, as I've had to add new ones to suit my suspension and tank layouts.
I simply measured the space fore and aft of my diff, with the transfer case and rear crossmember ( literally at the end of the chassis) being the point of termination.
You will need to consider many more things that I did, like shocky crossmember, shocks, exhaust, existing tank etc.
I just don't see it fitting mate.
Post Posted: Mon May 07, 2012 12:51 pm
oh well i will stick to my original plan with the stock tank beside the tail shaft and a LWB vit jobbie behind the diff.
Post Posted: Sun Dec 09, 2012 11:10 am
For sale again, $150 and they are yours
Post Posted: Wed Dec 12, 2012 3:35 pm
bump.
Vehicle: '84 LWB 1LTR
Post Posted: Sat Dec 15, 2012 12:01 am
Just to help out my LWB vit tank was out of a 2.5 V6?? If thats right sorry don't really know my vits but wasn't a 1.6. And it originally was just over 800mm wide. You don't have to knock it in by much. More just the centre flange then anything.
Here is a couple of pics of mine.
Filler Neck Side
Opposite Side
There isn't a great deal in it. Rear mounting cross member on the LWB Sierra will have to be cut out and a new made. The front mounts will work with some mods and overall the tank sits 50mm roughly further back them the stamdard tank. And still allows you to leave the factory shock mounts and setup standard.
Post Posted: Fri Dec 21, 2012 5:46 pm
Thanks for pics there Jim. Will see if I can find mine of the installation.
Users browsing this forum: Google [Bot] and 21 guests
