| Author |
Message |
tsock0
Vehicle: 93 vitara estate
 Posted: Thu May 10, 2012 8:12 pm |
hi all just need to know breifly will 30x9 fit on standard 93 vitara rims ? cheersss
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Thu May 10, 2012 8:16 pm |
7" rim would be the best fit but it will fit on a 6" but will be a tad baggy..... so to speak.
tsock0
 Posted: Thu May 10, 2012 8:21 pm |
Shansh
Joined: Sun May 23, 2010 9:35 am Posts: 1816 Location: Goulburn NSW
Vehicle: Ducati Monster
 Posted: Thu May 10, 2012 8:25 pm |
like mc hammer pants..............
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu May 10, 2012 8:30 pm |
6" would be fine in my opinion. 235's are run fine on 5.5" rims. My rule is to have more than 2" tyre width to rim to avoid breaking beads and filling beads with dirt/rocks at low pressure.
_________________ mlm
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Thu May 10, 2012 8:35 pm |
tsock0 wrote: what u mean by baggy? Too much tyre on too narrow a rim makes for roll under cornering and more chance of burping/loosing a bead when off road. 9.5=6" rim 10.5=7" rim 12.5=8" rim Steve.
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Thu May 10, 2012 8:48 pm |
Standard vit rims are only 5.5 wide
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
tsock0
 Posted: Thu May 10, 2012 8:52 pm |
alrighty then so is a standard vitara rim 5.5 inch or 6??
ill double check tomorrow what mine r exactly
Gwagensteve
 Posted: Thu May 10, 2012 9:28 pm |
tsock0
 Posted: Thu May 10, 2012 10:04 pm |
how wil my 30x 9.5 go on these or should i look for some wider rims
atari4x4
 Posted: Thu May 10, 2012 10:11 pm |
will be fine... people run a 235/75r15 on the stock rims & that's basically 9.5" wide
Fatzook
 Posted: Thu May 10, 2012 10:16 pm |
atari4x4 wrote: will be fine... people run a 235/75r15 on the stock rims & that's basically 9.5" wide I wouldn't say they will be FINE. Its not ideal, but they will fit.
banga
Joined: Tue Nov 17, 2009 10:30 pm Posts: 668 Location: sunshine coast
 Posted: Fri May 11, 2012 5:06 am |
alot of tyre shops wont fit them on there for you i had 235's fitted to stock rims never had issues with them except got to stay off full lock rubs on chassis (you could just adjust your steering stops) got them on 7" rims now they look heaps better.
_________________ lseries 2" body lift king springs 27" boots and a
tsock0
 Posted: Fri May 11, 2012 5:26 am |
Hmmmm anyone got some cheapish 7 inch rims for sale?
C how i go i just bought these 3ox9 maxxis at from ebay $99 so for that price its worth changing them first i think
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri May 11, 2012 2:30 pm |
I ran 235s on standard rims for years. Never a problem running 8psi, I drove all the hardest lines an tracks the hunter valley had to offer. I'm going to take the 15x8s off my current 235s and fit up standard rims. Cause if a drive in dust it gets in my beads
Fatzook
 Posted: Fri May 11, 2012 2:34 pm |
31zook wrote: I ran 235s on standard rims for years. Never a problem running 8psi, I drove all the hardest lines an tracks the hunter valley had to offer. I'm going to take the 15x8s off my current 235s and fit up standard rims. Cause if a drive in dust it gets in my beads  You have 235's on 8" rims?
31zook
 Posted: Fri May 11, 2012 3:02 pm |
Fatzook wrote: 31zook wrote: I ran 235s on standard rims for years. Never a problem running 8psi, I drove all the hardest lines an tracks the hunter valley had to offer. I'm going to take the 15x8s off my current 235s and fit up standard rims. Cause if a drive in dust it gets in my beads  You have 235's on 8" rims?  Yep   Not by choice, it's how I bought em. Looks like 31s on 8s I rekon.
Fatzook
 Posted: Fri May 11, 2012 5:43 pm |
Yeah doesn't look that bad.
tsock0
 Posted: Fri May 11, 2012 10:04 pm |
nice thanks for the replies and input ima gunna jst try them on the stocks first whilst lookin for some wider rims, by the way do old ford rims like falcon fit the vitara?
atari4x4
 Posted: Fri May 11, 2012 10:13 pm |
nah old ford rims wont fit. you're after a wheel with a PCD 5/139.7mm or 5/5.5" eg F100 & early jeeps
DarkHorse
 Posted: Fri May 11, 2012 10:45 pm |
atari4x4 wrote: nah old ford rims wont fit. you're after a wheel with a PCD 5/139.7mm or 5/5.5" eg F100 & early jeeps  Just those old Fords.
tsock0
 Posted: Fri May 11, 2012 10:58 pm |
yeah i was kinda confused too
lol
DarkHorse
 Posted: Fri May 11, 2012 11:49 pm |
There's a complete list on here somewhere of rims with a 5 on 5.5 PCD. Search is your friend.
christover1
 Posted: Sat May 12, 2012 8:40 am |
Copied from a post by CJ on our club site For future reference the following are stock rim sizes and offsets taken from the Tyre Industry Bible plus a few aftermarket steel rims. Feel free to add any others. Centre Bore 108mm PCD 139.7mm or 5.5" except Grand Vitara '05 onwards 114.3mm or 4.5" Wheel Stud (5x) M12 -1.25 ('98 & earlier) M12-1.5 ('98 & on) Please confirm. Model Rim Size Offset Sierra 15' x 5.5" 10P Vitara 15" x 5.5" 25P Vitara 2.0 V6 & 4cyl 16" x 6.5" 25P (steel & alloy) Grand Vitara/XL-7 16" x 7" 5P Jimny 15" x 5.5" 5P Grand Vitara '05 on 16" x 6.5" (45P) Grand Vitara '05 on 17" x 7" (45P) Speedy Desert Rat 15" x 6" -3 Speedy Desert Rat 15" x 7" -15 Speedy Desert Rat 15" x 8" -28 Speedy Desert Rat 16" x 7" 0 ROH Trak II 15" x 7" 3P ROH Trak II 15" x 8" -10 King 15" x 7" -13 King 15" x 8" -23 King 16" x 7" -13 Dynamic 15" x 7" 5P (approx.) Dynamic 15" x 8" -9 (approx.) & -25 (approx.) This site has a quick backspace/wheel offset conversion chart and also tells how to measure and do the calculations. http://www.wheelandtiredesigns.com/tech.php
tsock0
 Posted: Sun May 13, 2012 1:30 pm |
checked out that site nothing about suzukis unfortunetly
tsock0
 Posted: Sun May 13, 2012 1:34 pm |
 checked out that site nothing about suzukis unfortunetly would these jeep rims fit? 15 x 7 446r1pat 4610482
