It is currently Mon Nov 02, 2026 6:13 am
Post Posted: Sat May 05, 2012 6:47 pm
So I had a bit of left over plywood and carpet from another project. There is a bit of wasted space inside the tailgate of a Sierra as there is usually just a flat panel over the inside leaving 3 big voids behind. I though I would make up a panel that could be used for a bit of storage.
The holes are the perfect size to store a few straps. I need to get a bit of elastic or something to go across the front to keep it all in place. The webbing down the middle gives something for elastic to run under and that was also leftover.
It also allows me to put a flip down table over the top as the straps sit flush with the panel I made. I might see if I can find some black screws also.
Post Posted: Sat May 05, 2012 9:04 pm
Nice.
I ran a similar idea on my old Sierra,
but no where near that nice a job Armsup
Vehicle: Suzuki Grand Vitara
Post Posted: Sun May 06, 2012 10:10 am
Nice, look great
Vehicle: 84 suzuki sierra jx S/T
Post Posted: Sun May 06, 2012 4:13 pm
thats awesome. going to be doing mine next weekend haha
cheers mate :)
Post Posted: Sun May 06, 2012 5:31 pm
It's pretty handy i reckon. It's nice to have all the recovery gear easy to access a 9m strap is a tight fit and will stay in there without assistance. Next job for me is to rebuild the carby.
Post Posted: Sun May 06, 2012 10:35 pm
Bet the already overloaded rear door hinges will love that extra weight....
But nice execution :wink:
Vehicle: SJ51T
Post Posted: Mon May 07, 2012 6:27 pm
needs more dirt.
Humble beginnings
Post Posted: Fri May 11, 2012 8:16 pm
i got te led's mounted in mine on this one....but my last one i made a similar sort of thing! with a 6x9 speaker each side and a pocket in the middle for maps!
nice job bud!
back in a built sierra!
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat May 12, 2012 8:26 am
Nice idea,I'm doing a build know so awesome idea I'd be worried about weight if any of those things weighed anything much it could cause probs, wat about dings though did u pad the inside of the tailgate
Green? greeeen is nice !
Post Posted: Sat May 12, 2012 8:47 am
I wasn't too worried about weight. A couple of straps dot weigh a whole lots and it's not like I have a big tyre hanging off the tailgate either at the moment. I didn't do anything about padding the inside it could quite easily be done but I figured a couple of straps wasn't going to dent it might just get a few scratches. I'll see how it goes for now.
Post Posted: Sun May 27, 2012 6:56 pm
let us know how it goes
Post Posted: Mon May 28, 2012 7:23 am
Where do you put the straps once you've used them? 9 times out of 10, they'll be muddy once you have finished a recovery.
Steve
Post Posted: Mon May 28, 2012 7:48 am
That's true. I haven't really had a chance to test it out yet. It would be fairly easy to clean out though, couple of tec screws and it's off. Could also be used for a range of camping gear as well. It just seemed a waste of space with the void in the tail gate so if lightweight stuff can be stored in it so much the better. I don't run a full size spare so hopefully the hinges will be ok.
Post Posted: Fri Jun 01, 2012 8:49 pm
It is a good idea to store straps and i will use this trick to store my straps. i think it is a right think to use waste space and we can other lightweight stuff to store. Can you helps me to get more idea for store other lightweight goods.
Vehicle: 1992 SJ70 stock as a rock
Post Posted: Sat Jun 09, 2012 2:57 pm
Great fit out, don't worry about the weight the hinge can handle it. I made a basic version with thin sheet on a piano hinge at the bottom and three individual doors. When sprayed the same colour as the car the crooks can't see it even with the roof off. Just put the heaviest stuff near the hinge and all is good.
oh... dirty snatch straps hang off the spare wheel, every one knows that...
Users browsing this forum: No registered users and 10 guests
