It is currently Wed Aug 05, 2026 3:27 pm
Vehicle: 1999 Jimny
Post Posted: Mon May 14, 2012 9:59 pm
For those who know, what is the largest tyre you can get under a standard GV??? Don't want anything stupid. The standard tyre is just over 27" so will a 30" fit???
You have ANY lift?
Post Posted: Mon May 14, 2012 10:02 pm
With no lift a 225/70r16 will fit
Vehicle: 1999 Jimny
Post Posted: Mon May 14, 2012 10:12 pm
NO lift yet, Was looking at some 245/70x16s today there about 29.5" so I might just have to wait.
Post Posted: Mon May 14, 2012 10:25 pm
they will scrub.
A 225/75 16 is the same height, but a little narrower.
Post Posted: Mon May 14, 2012 10:48 pm
they will scrub.
Yeah, mine with dobinson and 15mm spacer which equates to 30mm up front rubbed on the firewall side whilst turning. needed to trim a little and massage with 4lb hammer :wink:
Vehicle: Jeep
Post Posted: Tue May 15, 2012 4:23 am
The rear wheel arch is the narrowest, about 30.5in or 76cm, and a problem for choosing a tyre, i know had to look around alot... i settled on a 225/70/16 to be safe, but a 225/75/16 will fit... i really wanted a 235/70/16, but not many 4x4 tyres come it that size, if any, and the ones that do, i didnt like... :D
Vehicle: 1999 Jimny
Post Posted: Tue May 15, 2012 2:25 pm
O.K. I'll be waiting for a bit then....... Suspension first, then bigger feet!!!
Post Posted: Tue May 15, 2012 10:22 pm
245-75-16 is the largest tyre you will want to go under a GV. without lift they will rub alot. with lift they still rub but not as bad. Plastic trimming is required for them to fit nicely
Users browsing this forum: BZOOK, Google [Bot] and 233 guests
