| Author |
Message |
Deego
Vehicle: Suzuki sierra
 Posted: Tue May 15, 2012 4:54 am |
Do the sierras have a brash bush that holds the axle centeral
Fatzook
 Posted: Tue May 15, 2012 5:13 am |
There is one in the back of the hub spindle. I'm not sure that its purpose is to hold the axle central, but it does remove a little bit of float from the CV.
Deego
 Posted: Tue May 15, 2012 5:24 am |
I'm doing a complete overhaul in the front.just wondering should I replace that to
Fatzook
 Posted: Tue May 15, 2012 5:28 am |
Deego wrote: I'm doing a complete overhaul in the front.just wondering should I replace that to Nope. They don't wear out. I've never even heard of somone replacing one. Just do your inner oil seal, Felts, king pins, wheelbearings and dust seal, and re-grease your CV and locking hub assembly, and thats it.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Tue May 15, 2012 9:10 am |
It seems the toyota guys change them because the axle seals must be abit shit.
If the axle seal wont seal. This bush can be the problem.
Im yet to change one.
Deego
 Posted: Tue May 15, 2012 9:23 am |
What is the name of them if I won't to get sone
BlueSuzy
 Posted: Tue May 15, 2012 10:49 am |
If you just explain where it is you should be able to order one.
Swivel hub brass bush
303zuke
 Posted: Wed May 16, 2012 11:23 am |
I don't think they're even available as a separate part, certainly not from Suzuki where it is an integral piece of the spindle. As others have said, I've never heard of anyone having to replace one because they flog out your axle seal.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Wed May 16, 2012 12:09 pm |
Pretty sure you can't replace them. They are part of the spindle, so you would have to buy a new spindle hub.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
BlueSuzy
 Posted: Wed May 16, 2012 1:30 pm |
The bush is brass/bronze, The knuckle/hub is not.
So.. they are replaceable.
Whether you can buy them or not is a different story.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed May 16, 2012 2:05 pm |
BlueSuzy wrote: The bush is brass/bronze, The knuckle/hub is not.
Whether you can buy them or not is a different story. /\ /\ X 2 I've never seen one that wasn't reuseable.
