| Author |
Message |
Taff
Joined: Sun Aug 13, 2006 11:30 pm Posts: 889 Location: Brisbane
 Posted: Sun Apr 12, 2009 4:03 pm |
Just put some brand new OME springs in the back of the LWB.
New bushes
Stock shackle
No excessive weight in the back.
The shackle angle is nearly horizontal, and they keep going past horizontal and staying there over bumps.
Anyone had this before? I cant figure out why it happening but its extremely annoying, makes the ride really bad.
A quick fix would be longer shackles but i would rather avoid them if i can.
brendan
Joined: Sun Jul 27, 2008 11:30 pm Posts: 1484 Location: Sydney
 Posted: Sun Apr 12, 2009 8:29 pm |
got pics
_________________ navara on 33s. hopfully rear air locker soon
Saam
Joined: Mon Jun 12, 2006 11:30 pm Posts: 2068 Location: Sunshine Coast
 Posted: Sun Apr 12, 2009 8:44 pm |
springs need to settle maybe, put some shit in the back for a couple weeks
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Sun Apr 12, 2009 8:55 pm |
i think you mean vertical. got pics?
_________________ builder of custom road legal zooks......and stuff.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Sun Apr 12, 2009 9:03 pm |
if they are horizontal your springs are too long you mean vertical right??
Taff
 Posted: Sun Apr 12, 2009 11:09 pm |
no i mean horizontal.
anyway, i went to take a pic and realised my stupidity.  in my hurry to change the springs (doing it before work) i forgot to put the new bush in the chassis end of the shackle. this bush was totally flogged out and essentially made the shackle shorter.
I will put new bushes in there tomorrow morning
Will take a pic tomorrow anyway so you can all laugh at my stupid stuff up
Taff
 Posted: Sun Apr 12, 2009 11:11 pm |
And here i was thinking ARB must have given me some special extra long springs
Taff
 Posted: Mon Apr 13, 2009 2:50 pm |
So i replaced the bushes and its still doing it.
just to clarify:
New OME springs
New bushes
Stock length shackles
Shocks are not the problem
At ride height shackles are sitting a bit lower than 45 degrees, with any bounce on the car they go past horizontal and lock up against the chassis.
Will get pics once camera gets some charge into it.
Seriously seems like the springs are too long, however afaik OME only make one length for the rear.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Mon Apr 13, 2009 3:02 pm |
is there a part number on the spring? maybe your car had a
F.U.R conversion.
Taff
 Posted: Mon Apr 13, 2009 3:05 pm |
heres some pics.
Ride height:
With a bit of a bounce:
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Mon Apr 13, 2009 3:10 pm |
yeah, they are a tad long. to much for even the front bush to flogged out.
Check the code on the spring & I think ya might find they are a stuff up.
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Mon Apr 13, 2009 3:13 pm |
Shit eh. Did you end up replacing the bushes that you forgot to change?
_________________ SJ50.4.LYF
Taff
 Posted: Mon Apr 13, 2009 3:17 pm |
Only numbers on the springs are
CS038 this might be longer as it goes under the axle housing. Cant read it fully.
and
6N08
Taff
All bushes are brand new from bruce.
Damo
 Posted: Mon Apr 13, 2009 3:20 pm |
How do the main leaf lengths compare to your old springs?
Taff
 Posted: Mon Apr 13, 2009 3:32 pm |
similar if not the same.
the old springs were OME heavy duty, but i totally destroyed them with axle wrap... pulled to many leaves out aiming for a softer ride. Gears+1.6 killed them no worries
these are OME med duty.
The answer must lie in the bushes, as that's realistically the only thing that has been changed.
Will pull them all out again this week sometime and check them all.
Damo
 Posted: Mon Apr 13, 2009 3:42 pm |
Taff wrote: similar if not the same. the old springs were OME heavy duty, but i totally destroyed them with axle wrap... pulled to many leaves out aiming for a softer ride. Gears+1.6 killed them no worries  these are OME med duty. The answer must lie in the bushes, as that's realistically the only thing that has been changed. Will pull them all about again this week sometime and check them all.
Can't see how the bushes could make that much difference, that's really odd. Will be interesting to see what you find when you look closer.
Skinny_Man
Joined: Fri May 23, 2008 11:30 pm Posts: 27 Location: North Brisbane
Vehicle: XL7/GV/Sierra/Drover
 Posted: Mon Apr 13, 2009 9:35 pm |
check the length with ARB, wouldn't be the first time they have done something like that (wrong spring or made wrong)
joeblow
 Posted: Mon Apr 13, 2009 10:19 pm |
Skinny_Man wrote: check the length with ARB, wouldn't be the first time they have done something like that (wrong spring or made wrong)
generaly springs are not 'made' wrong. first thing, did you take free hight measurements before install? this is a measurement from top of each eye then down to centre bolt. this measurement can be matched to ome spec sheet. then did you take before and after measurements on the vehicle from rim to guard. this measurement can also be used to work out spring specs. this is why ome have a disclaimer on self fits. personaly i have installed that many ome springs and i have never come across this problem. will be interesting to see what it turns out to be.
Taff
 Posted: Mon Apr 13, 2009 10:42 pm |
I'm not dissapointed with the product at all nor am I blaming it. I love my OME springs... this is my third set.
Just a pity you gotta get em from ARB
No i didn't take any measurements on free height. as for rim-guard i didn't care.... i wasn't chasing lift so i wasn't concerned by how much it came up or down.
I'm going to check all the bushes and see what i can find. if nothing shows up i will just extend the shackles by 25-30mm.
ajsr
 Posted: Mon Apr 13, 2009 11:18 pm |
measure them from eye to eye centers.
measure them upside down from mainleaf to concrete.
ive got a brand new never fitted set of rears sitting in my shed ill check for you.
If they are longer than mine i'll swap you. More flex yeahhh
cheers andrew
joeblow
 Posted: Mon Apr 13, 2009 11:29 pm |
ajsr wrote: measure them from eye to eye centers. measure them upside down from mainleaf to concrete. ive got a brand new never fitted set of rears sitting in my shed ill check for you. If they are longer than mine i'll swap you. More flex yeahhh cheers andrew
brand new ome, or brand new ome dakar? they are different lengths.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Mon Apr 13, 2009 11:31 pm |
joeblow
 Posted: Tue Apr 14, 2009 12:27 am |
Zook_Fan wrote: which ones are better?
dakar.
Zook_Fan
 Posted: Tue Apr 14, 2009 12:28 am |
dakar are longer? dammit i was going to get the dakar's but heard that just ome are the way to go
ajsr
 Posted: Tue Apr 14, 2009 12:38 am |
Taff
 Posted: Tue Apr 14, 2009 7:29 pm |
OK i think i might have found a possible cause.
The shackles are not looking too healthy after 20+ years of abuse
What do you guys think?
If i drill some flat bar as shackles would it be fine to use 4mm steel? its only in the back, they will only be stock length.
Hybrid
Joined: Mon Apr 21, 2008 11:30 pm Posts: 1095 Location: Bulimba, Brisbane
Vehicle: '92 Sierra
 Posted: Tue Apr 14, 2009 8:38 pm |
I could see how that could cause some lateral movement of the shackle and also how you'd flog bushes out but I don't see how that can cause the shackles to invert EDIT well not invert but lock back like in the pic.
Hybrid
Vehicle: '92 Sierra
 Posted: Tue Apr 14, 2009 8:39 pm |
Taff
 Posted: Tue Apr 14, 2009 9:05 pm |
the pictures are doing it a favour.
the holes being elongated like that, the way i see it, are making the shackles about 10-15mm shorter. this is letting them fold back.
Or am i still right off track with this one?
