It is currently Sat Oct 31, 2026 11:38 am
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Sat Jun 09, 2012 8:04 pm
I did mine similar if you look through the made it section I would find it,and,put a lnk but on my phone. I have found problem with leaving the front a arm bolts exposed I punch mine with a rock wrecks the bush. I'm gonna make another one that covers bolts
Post Posted: Sat Jun 09, 2012 8:10 pm
My bolts have plastic covers at the moment,
but I like the idea of protecting them with metal
Post Posted: Sun Jun 10, 2012 5:27 pm
Post Posted: Sun Jun 10, 2012 5:31 pm
Excuse my bird dung welding,
luckily no one will see it :)
I ain't no where near good enough to weld bolts inside the tube,
so this worked for me.
Decided on 5 smaller bolts, instead of 2 big ones.
Less to get hung up on,
and I have lots of them lying around.
Not sure I'll stay with the button bolts yet.
Post Posted: Mon Jun 11, 2012 2:31 pm
It fits. But it is too shiny, needs dirt.
Hence the grubby finger marks :D
But I need new A-arm bolts, the originals stripped,
the bolts I used are a tad too short.
That is tomorrows problem.
I'll get away with stock length bolts,
as I don't have the sway bar bracket fitted.
People who do may need longer bolts.
Post Posted: Tue Jun 12, 2012 3:38 pm
Cutting done.
Had to buy a new angle grinder half way through.
My Makita served me well.
(After taking back 3 Ozitos they pleaded with me to buy a better one :) )
Took a chance on another Ozito this time.
Last time I buy Ozito anything.
Would not even start.
Took it back and got a Ryobi, also cheap, but less crappy, it worked.
Ready for bending now.
Note the Hi Tek measuring and shaping eqipment :)
Think I may make, buy or borrow a decent bender,
because there's a few times I'll need one again.
Post Posted: Wed Jun 13, 2012 2:08 pm
Testing the booty fab bender on an offcut.
Hopefully won't snap the end off the bench.
Have large manly washers under the nuts,
but may run another bit of steel underneath.
It bent ok to the angles I need.
Would need a higher tech approach if needed sharp 90* bends
Post Posted: Wed Jun 13, 2012 2:24 pm
Weld some hinges between the angle and another bit facing the other way then weld a handle on it
That way u can pull down on it
You.should make 2 bottom pieces
One with a nice sharp edge for tight thin bends
The other with a nice radius for bending thicker plate
If u had like 150x10 plate on the bottom u can also cut 50mm x5mm slots so u can bend the plate with lips on the sides to gain strength
Post Posted: Wed Jun 13, 2012 2:51 pm
Thanks. I like those ideas, will definately look into it.
I don't trust my welding enough,
so I may think of some bolt on options.
Future project I think.
For now, I'm wanting only 45* bends maximum,
and prefer rounded corners for the bash plate.
Post Posted: Fri Jun 15, 2012 3:53 pm
Bender worked, I am pleased with the result. :D
Had to convert one end of my wheel bearing press into a press lever,
for the bends with only a small leverage area,
but most was done by my other huge press,
some call it my big fat ass.
I just sat on it and grunted a tad. :mrgreen:
Next is welding, a bit of trimming, then some bolt holes and paint.
Getting there
Post Posted: Fri Jun 15, 2012 4:16 pm
bloody good job mate, looks better than my calmini one!
Post Posted: Fri Jun 15, 2012 4:23 pm
Thanks.
I appreciate the encouragement.
It's beer o'çlock now :beer:
Post Posted: Fri Jun 15, 2012 4:47 pm
awesome work once again chris
Post Posted: Fri Jun 15, 2012 4:52 pm
Thanks.
My Monday welding may make it a little less awesome,
but I will be able to hide that with paint, dirt and mud :)
Vehicle: vits
Post Posted: Fri Jun 15, 2012 5:20 pm
If you haven't thrown out your old Makiita grinder bring it to Robe and I will try and fix it for you..... the good brands are usually repairable.
Post Posted: Fri Jun 15, 2012 5:29 pm
I put it in the drawer for a future fix.
Feels like its stripped a cog.
Motor picks up revs and cutter slows down.
But I may take it for a drive to Robe :)
I doubt the Ryobi will live long.
Post Posted: Fri Jun 15, 2012 9:18 pm
Nice work Chris, looks great!
Post Posted: Fri Jun 15, 2012 9:28 pm
Thanks.
Can't wait to finish it.
But I must be patient.
Things keep getting in the way.
And its too dark n cold in the shed before 10am and after 3pm :roll:
Post Posted: Sat Jun 16, 2012 9:55 am
Can anyone tell me if these button bolts are " strong " enough to bolt up the sump guard?
Can't see any markings on them.
They were sourced from hinges and doors and other areas off my old Sierra.
I have plenty of high tensile normal bolts if they aren'' t up to it.
Figured they may slide over stuff better than normal heads.
I have stepped the guard to be slightly lower than the rear bolts,
just in front of them.
Vehicle: LWB Sierra & XL7
Post Posted: Sat Jun 16, 2012 10:53 am
If I ask you really really nicely can you make one for me :D
Nice work.
'92 Vitara & Camper trailer
Post Posted: Sat Jun 16, 2012 11:02 am
Nice work.
Of course.
But 2 weeks at $15 pr hour would probably make them $1000 each :mrgreen:
Makes the Calmini ones more appealing :|
Post Posted: Mon Jun 18, 2012 3:53 pm
All welded up, drilled, trimmed, and ready for paint.
I decided the rear section needed a curve, bit of extra strength,
and matched curve of the cross member.
Did a fill? weld to join it to the side bits
Vehicle: vits
Post Posted: Mon Jun 18, 2012 5:23 pm
Great work Chris Armsup . Try a new set of brushes in your old grinder :wink:
Post Posted: Mon Jun 18, 2012 5:33 pm
That's spectacularly good work there Chris. You'd have to be happy with that.
Post Posted: Mon Jun 18, 2012 5:37 pm
Just killed me cheap ryobi dremel copy now.. I will search for receipt, may still be in warrantee.
Post Posted: Mon Jun 18, 2012 5:39 pm
Thanks, I am pleased.
I jumped on it with my full weight,
think it will be ok.
Only photographed the better looking weld though :oops:
Lucky I'm good with the grinder :mrgreen:
Post Posted: Mon Jun 18, 2012 7:36 pm
Good work Chris :D
Now go try it out :mrgreen:
Post Posted: Mon Jun 18, 2012 7:43 pm
monley wrote:
Good work Chris :D
Need to paint it first before I scratch it :)
Post Posted: Tue Jun 19, 2012 5:04 pm
I got a bit carried away, and painted the bolts, too. :oops:
Though the bolts got no undercoat/primer :roll:
Be good for the show n shine events :mrgreen:
Post Posted: Tue Jun 19, 2012 8:14 pm
You pretentious git! :lol: ;)
Interested to see how those phillips heads hold up after a few removals/reinstalls and some mud...
Users browsing this forum: No registered users and 38 guests
