It is currently Fri Jul 03, 2026 8:54 pm
Post new topic Reply to topic  [ 718 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 24  Next
Poll: Do You Rate and Reccomend The Chinese Air Lockers
Yes 59%  59%  [ 44 ]
No 41%  41%  [ 31 ]
Total votes : 75
Post Posted: Fri Jun 08, 2012 5:56 am
roxyjess493 wrote:
I have a problem with my china soong airlocker...
could someone please help me...i've used my locker 4 or 5 times...the locker is still engaged but yet there's no airlines attached...
does any one know what it could or does it sound familiar...
Did you use the right oil? Front or rear?
I remember reading something about them staying engaged. Maybe do a search?
Post Posted: Fri Jun 08, 2012 4:59 pm
did you turn it on with one wheel spining? Bang it will destroy the lock and wont unlock I reckon this is what your done.
 Profile YIM
Post Posted: Fri Jun 08, 2012 5:51 pm
Mine stays engaged all the time, if it's the front just turn your wheels left and right and it should disengage, mine does.
Or try reverse and turn the wheels, and why isn't the hose connected
Vehicle: suzuki sierra sj70
Post Posted: Sat Jun 09, 2012 6:36 am
It's in the rear...
Yeah it's the right oil...
We didn't turn it on while a wheel was spinning...
We're tried reversing it didn't work...
We took the hose off to make sure there was no air in it
Post Posted: Sat Jun 09, 2012 7:35 am
Put the air line back on and engage and disengage it a few times then reverse while turning.
If that doesn't work I'm afraid youll have to pull,it out
Vehicle: Suzuki Sierra SJ80
Post Posted: Sun Jun 17, 2012 9:28 pm
Does anyone know what model number would fit a rear diff of a 96 coily? and if they have any for the front diff?
Cheers,
Trev
Post Posted: Sun Jun 17, 2012 10:08 pm
Rd88 or rd208
Post Posted: Tue Jun 19, 2012 6:39 am
Been watching this thread for a while guys.
was thinking of making the plunge in the next couple of months, but going with a ARB locker. Ive already got a compressor fitted, and i prefer to run my own electrics and air lines. so the install would basically be for the locker itself only.
What would i expect ARB to slug me just to fit that on its own? am i better off taking the diff center out and taking it to them? if so, is that a big job to do and do would i need any precision measuring equipment to re-fit? Ive done ALL mechanical work on my car up to this point if that gives you an idea of my abilitys. its just the precision work im a bit nervous about.
MY BUILD THREAD HERE!!!!!
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Jun 19, 2012 7:02 am
I'm doing this in the next month or so :)
They're charging me $360 to fit both the lockers and I do the rest.
Lockers were around $1060 each
Post Posted: Tue Jun 19, 2012 7:15 am
is that if you take your car in? or the diffs?
wonder what theyll slug me just for the rear
Post Posted: Tue Jun 19, 2012 7:25 am
That's just taking the centres in... Otherwise the fitting is a little over $500 per locker :/
Post Posted: Tue Jun 19, 2012 7:36 am
okay, so are you able to answer the 2nd part of my question.
Is it hard to remove the center? is it just the guts of the pumpkin you take in? and how easy is it to re-fit
Post Posted: Tue Jun 19, 2012 7:41 am
From what I understand you have to remove axles and all the rest to get it out... Not exactly sure on the whole process, I'll have a mechanic helping me do it :)
Someone on here should be able to help you out with that but?
Post Posted: Tue Jun 19, 2012 7:52 am
Drop oil
Pull axles
Drop tailshaft
Undo allthe bolts around the center and pull out
It comes out in one peice dont need to doanything arb wil set it back up
Put some ultra grey around the lip when u put it back in
Post Posted: Tue Jun 19, 2012 7:59 am
Put the car on safe stands.
Remove oil from axle.
Remove wheels and axles.
Drop the drive (Tail) Shaft.
Remove nuts around differential.
Pull differential out.
Take to ARB and give them a heap of money.
Reverse the above order.
Done.
Vehicle: Ducati Monster
Post Posted: Tue Jun 19, 2012 8:07 am
Take to ARB and hope they tell you that you are pretty and kiss you a little bit before they screw you royally.
Done.
fuck ARB, some great products but they employ wankers and charge like wounded bulls!!
:lol:
Post Posted: Tue Jun 19, 2012 8:15 am
Done.
:lol:
I agree but he said he wanted to go there?
Post Posted: Tue Jun 19, 2012 8:19 am
i know, I was just taking a shot at ARB, didnt mean to sound like i was having a shot at you Tony, sorry if it did come across like that mate
Post Posted: Tue Jun 19, 2012 8:37 am
Not at all Shanish - I agree about ARB - I hate places that ripoff just because they build a name.
Post Posted: Tue Jun 19, 2012 9:19 am
Cost me $190 to fit all new bearings and locker into center at my local ARB.
Do what the boys said above to remove the rear center. If your getting the front done, there a bit more involved and it's a pita to get the front center back in.
Post Posted: Tue Jun 19, 2012 2:58 pm
Yopu may need a slide hammer to get the axles out (they can be a bastard at times) apart from that it is a fairly easy job.
Post Posted: Tue Jun 19, 2012 3:04 pm
yeah i was only keen on getting single locked when i eventually go ahead.
Sounds like a piss easy job, i can handle that. i was kinda thinking id have to get dial guages out n stuff around with tolerances or something. if not AWESOME!
If not ARB, who else would fit it??? keep in mind im in Brownsville.... dont know WHO to trust up here mech wise.
Post Posted: Tue Jun 19, 2012 3:08 pm
Any half decent mechanic should be able to do it, but bear in mind they have to be able to set up the back lash etc. so get some local refferals
Post Posted: Tue Jun 19, 2012 3:17 pm
Ok, ill put the feelers out amongst the 4x4 specialists in town. Just waiting from a call back from ARB, no one was available to talk to.
Is LROR still the cheapest for the RD208 for the rear. (i assume thats what i need on the Jim)
Post Posted: Tue Jun 19, 2012 3:23 pm
Yeah RD208. Yeah you'll save a couple hunge from LROR
Post Posted: Tue Jun 19, 2012 3:29 pm
just heard back from em, "yeah bout 300-350 if you bring center in"
he asks me a HEAP of questions about the locker, if its brand new in the box, is it arb etc etc. then i ask him what about the generic ones
"nope not touching it"
he rekons had another bloke bring one in (dunno what car), took the center out, pulled the locker out of the box and was missing a bit. couldnt get car off hoist until they got the part... now they wont touch em.
whatever.....
didnt bother asking how much locker was on its own.
Vehicle: 1985 Holden Drover
Post Posted: Tue Jun 19, 2012 4:45 pm
Haha cranky ARB not liking losing the money im guessing? :lol:
1989 WT Sierra.
Post Posted: Tue Jun 19, 2012 5:28 pm
that's a rip off imo, $300 is too much, i hear every one complain how cranky arb and there high price are.
my local one is ran by a family and there always more then happy to help, cheap too.(laybour work)
also if you get it done by arb, then you will have some thing to full back on if some thing goes to shit.
rd208 from lror should be about $960 delivered, that what it cost me last year. price could change by thenn though.
Post Posted: Tue Jun 19, 2012 6:49 pm
$300-$350 is a crap price for fitting. It would cost me $400 for a drive-in, drive-out locker fit out at my local ARB....my rear locker was $1550 fitted...yeh steep when you could save $200-$400 on labour and getting one from the US, but WHEN it packs up, you simply drive back to ARB and tell them to fix it :wink:
Post Posted: Tue Jun 19, 2012 7:44 pm
LROR was 960 PLUS postage when i looked today, so 1100 total pretty much.
I figured its a steep price to fit. but what choice do i have? short of driving to cairns and trying that ARB.
Users browsing this forum: Google [Bot] and 179 guests
