It is currently Mon Nov 02, 2026 9:03 am
Post Posted: Wed Jun 27, 2012 4:43 pm
How are Jimny front bumpstops fixed and removed?
Where could I get longer replacements. This hasn't been a necessity till now with the 32's.
I have found nothing with the search function. It keps ignoring the word 'jimny'. Thats just rude. :sup:
Post Posted: Wed Jun 27, 2012 8:48 pm
Where are the tyres hitting? Just keep hammering...
Post Posted: Wed Jun 27, 2012 9:42 pm
you can get replacements from zanifi.it or something like that. they are very expensive and your better off welding a piece on to the where the stock rubber stopper hits on to. as unless your car is brand new i doubt you will be able to unscrew them.
Post Posted: Wed Jun 27, 2012 9:48 pm
plenty of bumpstop info in here viewtopic.php?f=17&t=8087&p=568166&hilit=bumpstop#p568166
even jimny stuff :lol:
Post Posted: Wed Jun 27, 2012 10:43 pm
Ok, so they screw in and out? Mine did rotate freely, but did not unscrew.
No more to hammer. I have pushed the firewall back as far as I need. It is now the underside of the wheel well (inner guard) under full coil bind.
Post Posted: Thu Jun 28, 2012 6:21 am
Nothing in that link about Jimny front. Only rear, which is easy to see by looking at the vehicle. Front, not so much.
Post Posted: Thu Jun 28, 2012 6:36 am
Ok. By looking at the zanfi site, I can see that blocks are not a direct fit using factory fit. They use a bolt to drop through from the hole in the top of the tower through the mating surface and into the block. Easy enough to make with a lathe.
Users browsing this forum: Google [Bot] and 110 guests
