It is currently Tue Nov 03, 2026 12:32 pm
Post Posted: Tue Jun 26, 2012 11:09 pm
When I park the Jimny on even a slight upward angle, the rear stem leaks washer fluid and will eventually empty the reservoir. In a matter of an hour or 2.
I am thinking a small one way valve might work. They are of course designed to stop fluid flowing back the other way, but I am thinking it might offer enough resistance to the fluid whilst at standstill (ie, not being pumped).
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290592269683&fromMakeTrack=true
Any other suggestions?
Post Posted: Wed Jun 27, 2012 8:56 am
Wayne that might work and for $5 it's worth a try.
Post Posted: Wed Jun 27, 2012 4:40 pm
Rang Repco today. They have one for $8.50. Might drop in and have a gander some time.
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Jun 27, 2012 6:31 pm
I have the same problem and a steep driveway, so mine empties overnight :(
I may not understand exactly what you're doing, but wouldn't a one way valve stop it going down the line even when it is pumping?
Post Posted: Wed Jun 27, 2012 11:43 pm
Only if it is installed backwards. I intend to install it in the direction of flow. I am not trying to stop backward flow, but rather utilising the spring close action of the valve (a thin rubber disc I imagine) to stop leaking of fluid under nil pressure.
Post Posted: Wed Jun 27, 2012 11:45 pm
there will one in the tail gate/rear section already, otherwise every time you press the rear washer it would have to prime the whole line from the washer bottle.
Post Posted: Thu Jun 28, 2012 12:25 am
Hmm. Maybe that one is faulty and therefore why it is leaking. Will have to check it out.
Post Posted: Thu Jun 28, 2012 1:40 am
Its probably working fine.... your trying to stop the flow in the opposite direction.
Vehicle: 99 Dirty Green Jimny
Post Posted: Thu Jun 28, 2012 9:40 am
Exact same happens to my jimny, and I searched around before and found a few topics, some people just blocked it completely and disconnected the pump.
Let us know how you go with the new valve, I imagine a heavy duty one will probably have enough spring pressure to stop gravity flow on a hill, the motivation to fix it is less than filling often from the tap in my driveway atm for me.
Post Posted: Thu Jun 28, 2012 10:45 am
My motivation is that its empty when I want to use the wipers :(
Post Posted: Thu Jun 28, 2012 11:08 am
I rarely use the rear wiper! Only if it rains. Then its wet
Post Posted: Thu Jun 28, 2012 11:25 am
Same, but when its empty, no washer, front or rear.
And its the detergent in the washer that makes the difference. I use Bars Bugs.
Post Posted: Thu Jun 28, 2012 11:50 am
Something like this would be good but I think 15psi is too much. 5psi would be plenty.
Maybe they can be pulled apart and weakened.
http://www.jbsautodesigns.co.uk/product ... e-4mm-hose
I'd be fitting one of these...
Stainless.
Can handle fluids.
Is NC until powered.
Would be ideal as it can be connected to squirter pump power so is only letting fluid through when you want squirters working.
Not sure about P&A but I'm sure someone local will sell them.
Post Posted: Thu Jun 28, 2012 11:59 am
do you even use the rear washer?
Post Posted: Thu Jun 28, 2012 12:04 pm
It would be a spring inside
Post Posted: Thu Jun 28, 2012 4:48 pm
atari, not often, but that's not the point. When I want to use the front, the reservoir is empty because its leaked out the back. Only happens when the vehicle is on an incline of more than about 5 degrees.
Wan33s. I purchased a $3.60 one way valve today from Bursons. I'll chuck that in the system and see if that helps. A cheap punt. If not, I'll search for that solenoid tap.
Post Posted: Thu Jun 28, 2012 5:13 pm
simply block it off then. what you're wanting to do, won't work as the pressure from the washer motor will close the 1 way valve with it fitted the way you're intending.
Post Posted: Thu Jun 28, 2012 6:00 pm
Post Posted: Tue Sep 18, 2012 1:52 pm
http://www.bigjimny.com/images/document ... er_jet.pdf
found this for anyone interested.... been meaning to post it for ages lol
Users browsing this forum: No registered users and 72 guests
