| Author |
Message |
Deego
Vehicle: Suzuki sierra
 Posted: Tue Jul 03, 2012 3:48 pm |
I'm changing my sump gasket and I'm wondering whats the best sealant to use
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jul 03, 2012 6:03 pm |
Deego
 Posted: Tue Jul 03, 2012 8:09 pm |
How hard is it to change a sump gasket.do you put the sealant both sides of the gasket.
atari4x4
 Posted: Tue Jul 03, 2012 8:12 pm |
there is no gasket used on suzuki sumps only the sealant...
clean both surfaces so they're spotless, apply a bead around one of the flanges (engine or sump) & around the bolt holes, let it tack off slightly, then refit the sump.
Deego
 Posted: Tue Jul 03, 2012 8:18 pm |
Why do they sell the gasket then
royce
 Posted: Tue Jul 03, 2012 8:33 pm |
atari4x4 wrote: there is no gasket used on suzuki sumps only the sealant...
clean both surfaces so they're spotless, apply a bead around one of the flanges (engine or sump) & around the bolt holes, let it tack off slightly, then refit the sump. there is a cork gasket available for 8 valve engines
atari4x4
 Posted: Tue Jul 03, 2012 8:44 pm |
royce wrote: atari4x4 wrote: there is no gasket used on suzuki sumps only the sealant...
clean both surfaces so they're spotless, apply a bead around one of the flanges (engine or sump) & around the bolt holes, let it tack off slightly, then refit the sump. there is a cork gasket available for 8 valve engines sorry boss, didn't realise that there was one for the 8 valve, i was recalling this post of losfers & his hate of cork gaskets... losfer wrote: on a side note , i absolutely hate cork gaskets , i prefer a high temp rtv silicone myself , i am that confident , that i would use a silicone , let it cure , then remove all the bolts and drive around .
most suzukis left the factory with silicone (3 bond) as a sump gasket. when you go to remove the sump from the engine it takes quite some force.
the only time i will ever use a cork gasket is in a "in car situation" where theres a possibility of scraping some of the silicon on something else and compromising the seal , in this case i will use a cork gasket that is glued to the sump using contact adhesive , you should never use a silicon sealant with a cork gasket.
Deego
 Posted: Tue Jul 03, 2012 8:50 pm |
Can ya get away with one for a 1.3l serria.by the way I know this might be a silly question but what do you mean bead.
atari4x4
 Posted: Tue Jul 03, 2012 8:51 pm |
when you squeeze the tube & the stuff comes out like a worm... that's a bead.
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Tue Jul 03, 2012 9:13 pm |
Suzi Store list a cork gasket for the 16v engine, but when ordered they send a 8v gasket
_________________ Watch out or you'll get sued.
Deego
 Posted: Wed Jul 04, 2012 4:12 am |
Can I get away with just putting the sealant on.some people say you don't need the gasket.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed Jul 04, 2012 4:17 am |
Yesss
_________________ mlm
Deego
 Posted: Wed Jul 04, 2012 4:37 am |
Deego
 Posted: Wed Jul 04, 2012 4:57 am |
Can you also smear the sealant around the sump or you have to do that bead apply.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Wed Jul 04, 2012 12:33 pm |
Has to be enough so when you bolt the sump on, the silicone squishes and seals a good amount on both sides.
Both sides must be clean of oil.
Most of my oil gaskets go in the bin to run silicone only.
squibby
Joined: Wed May 11, 2011 3:13 am Posts: 645 Location: Brisbane
Vehicle: On the lookout
 Posted: Wed Jul 04, 2012 3:03 pm |
This threads kinda been talked to death already, but I can vouch for the Locktite product pictured above and comes with clear instructions on how to apply.
_________________ Crispy old grand vitara
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5943 Location: Northcliffe, W.A.
 Posted: Thu Jul 05, 2012 1:12 am |
I rebuilt a 202 Holden Red motor once. Someone had used silicone instead of the cork gasket for the sump, bits of silicone had separated off and partially blocked the oil pickup. The bearings were nicely down to the copper. I like cork. Cork you idiot, not cock.
SierraDan
 Posted: Thu Jul 05, 2012 3:44 am |
A mates 253 had the same issue with the silicon.
But for a Sierra motor it works just fine.
Jackson
Joined: Mon Apr 04, 2011 5:56 am Posts: 559 Location: Newcastle
Vehicle: Yellow Ute
 Posted: Thu Jul 05, 2012 12:04 pm |
sideways wrote: I rebuilt a 202 Holden Red motor once. Someone had used silicone instead of the cork gasket for the sump, bits of silicone had separated off and partially blocked the oil pickup. The bearings were nicely down to the copper.
I like cork. Seen the same in a mates hilux motor The problem is people must think they need to use the whole tube for a thermostat housing.
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Sat Jul 07, 2012 7:50 am |
No the problem is that there are numerous silicone sealants but not all are designed to be used where oil is in play, if you use the correct one you will not have this problem.
Deego
 Posted: Sat Jul 07, 2012 9:45 am |
Could you tell us the right one to use mate.
want33s
 Posted: Sat Jul 07, 2012 9:50 am |
want33s wrote:
Deego
 Posted: Sat Jul 07, 2012 9:52 am |
And these are the ones where oil is in play
Deego
 Posted: Sat Jul 07, 2012 9:55 am |
Sorry I mean and these sealants good for what 2strocker commented before
want33s
 Posted: Sat Jul 07, 2012 9:57 am |
Deego wrote: And these are the ones where oil is in play It says on the packet on the right.."OUTSTANDING OIL RESISTANCE". Do you really think I'd recommend you use an unsuitable product?
Deego
 Posted: Sat Jul 07, 2012 10:01 am |
No sorry mate.thanks for that
Deego
 Posted: Tue Jul 10, 2012 1:49 pm |
I know you can glue the gasket to what's good glue to use
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Tue Jul 10, 2012 1:56 pm |
Deego wrote: I know you can glue the gasket to what's good glue to use Seriously, are you retarded? USE SOME GODDAMN RTV SILICONE THAT IS OIL RESISTANT!!!
tim80z
Joined: Tue Dec 14, 2010 8:09 pm Posts: 722 Location: Parkes NSW
 Posted: Tue Jul 10, 2012 3:49 pm |
Deego wrote: I know you can glue the gasket to what's good glue to use want33s wrote: - Tim.
Deego
 Posted: Tue Jul 10, 2012 4:42 pm |
Sorry what i mean is People use a Contact adhesive rather then silicon to glue the gasket on
