It is currently Thu Sep 17, 2026 12:57 pm
Post Posted: Fri Jul 06, 2012 3:48 am
hello all.
I have sj80 aka coily and i like to put 1ltr t/c inside..
i wonder if the case of 1ltr mount the same as 1.3ltr.
cause i have calmini tcase cardle which was ment to be used with 1.3ltr.
do you think the 1ltr. bolt on?
http://www.puresuzuki.com/t-case_mount.htm
Post Posted: Fri Jul 06, 2012 5:23 am
Should be fine mate
Post Posted: Fri Jul 06, 2012 10:10 am
i think the arms bolt on the same.
Post Posted: Fri Jul 06, 2012 10:27 am
the arms bolt the same to frame or to both transfer cases, the 1ltr and 1.3ltr?
both of the cases share the same case design?
Post Posted: Fri Jul 06, 2012 1:14 pm
sorry, to the case.
Post Posted: Wed Jul 11, 2012 3:49 am
Hello again and thanks for your replys !
I went and bought the 1lts t/c but i'm frustrated for many other things
well, you right. it fits nicely in the calmini cardle.. thanks again.
but i had to remove the drum handbrake and find a corect flange to go with my coily rear driveshaft. will the newer part on my coily will fit?
second, i bought long time ago driveshaft that come from an old model that (i think 84' lwb sierra) goes between the t/c and the transmition.
and it doesn't fit the 1lte t/c
can you help me to look for the right parts needed?
thanks !
Post Posted: Wed Jul 11, 2012 9:35 am
Hello epitam, what we usually do is remove the drive flanges from the I litre transfer and bolt on the drive flanges from your transfer that way your drive shafts all bolt up.
However there are two kind of 1 litre transfer case the earlier model can he recognised because it does not have a switch module for the 4x4 light and this model has different splines than the 1300 models.
If you have an early model you need to made a "hybrid" drive shaft by fitting 1 litre ends to your drive shafts, this can be achieved because the universal joints are the same size.
Hope that helps
Post Posted: Wed Jul 11, 2012 7:24 pm
2stroker thanks for your reply.
I have the model with the unit but does the regular 1.3t/c splines are the same as the coily t/c?
Second, if i'll not be satisfied with the 1ltr reduction will I be able to put full kit inside like 4.9 or even 6.5?
Thanks again! Much appreciated your help.
Post Posted: Wed Jul 11, 2012 7:27 pm
I have the model with the unit but does the regular 1.3t/c splines are the same as the coily t/c? YES
Second, if i'll not be satisfied with the 1ltr reduction will I be able to put full kit inside like 4.9 or even 6.5? YES
:wink:
Users browsing this forum: No registered users and 163 guests
