It is currently Mon Sep 21, 2026 12:07 am
Post Posted: Sun Jul 08, 2012 11:17 am
hey dudes,
Im just rebuilding my sierra t-case (as we speak) and im up to the first pin-bearing, now i know i have to grease it, what grease is suitable? and how much do i pack them? or is it just a dab on them?
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Jul 08, 2012 11:46 am
Pin bearing?
NFI what you mean. There are 2 types of bearings in a sierra transfercase. Needle bearings and roller (ball) bearings. The only one that needs a slight smear of grease is the tiny little internal needle bearing that the front output shaft runs in. The rest are bathed in gear oil.
All bearings should be lightly oiled before installation to prevent any dry damage occuring.
Post Posted: Sun Jul 08, 2012 11:52 am
ok needle bearings, pin bearing, cage bearing.... whatever! :lol:
the trail-gear instructions mention greasing the needle bearings when you fit them.
http://www.trail-gear.com/pdf/suzuk-tcase.pdf
I didnt replace that internal needle bearing, looked painful and i doubt theres anything wrong with it.
Post Posted: Sun Jul 08, 2012 12:05 pm
in addition, other people have mentioned greasing them in here before im sure.
Vehicle: Drover pickup turk
Post Posted: Sun Jul 08, 2012 12:17 pm
Bearing grease.
I like the tuna here
The oil dilutes the grease almost instantly.
Its probably the same as oiling the bearings. Just a safety net for initial start-up. In any case, a thin smear is all you will need.
Post Posted: Sun Jul 08, 2012 12:23 pm
okay sweet, ill just give it a little dab then. Thanks guys, i can get stuck back into it now.
OH ALSO!
the shifter ring thing in step 45... does it matter which way up that goes on? it has a bevelled edge and i can figure out if theres a difference either way!
Post Posted: Sun Jul 08, 2012 1:04 pm
i've never worried about it. The teeth are the same on bothe ends, so they slide just the same no matter which way tou fit the ring. I'd wager that its shaped as it is, to make casting the part easier.
Post Posted: Sun Jul 08, 2012 2:03 pm
ok sweet thanks mate. nearly all done now. wish i took pics but with those instructions, its hard to do much better!
Users browsing this forum: No registered users and 79 guests
