Author
Message
kenn
Posted: Mon Jul 09, 2012 12:21 am
If people are insecure that their idea won't bear scrutiny then they shouldn't post it on a forum. Steve.
I could say something, but I won't..
Gwagensteve
Posted: Mon Jul 09, 2012 7:16 am
JrZook
Posted: Mon Jul 09, 2012 10:27 am
OI Kenny! Back to Joe Blow's kitchen! There's been a spill and you have been required to mop it up asap
Lil Foot!
vitzookman
Vehicle: 2001 XL7
Posted: Mon Jul 09, 2012 11:09 am
can we get back to the tech? This is really interesting and im sure all the GV and XL7 owners will be interested How much more does the update XL7 put out than the 2001, also can you bolt update Plenum thingy straight onto a 2LV6, 2.5V6 and the early XL7? if we could cut out the Dick waving it could be a great thread for the tech section.
Gwagensteve
Posted: Mon Jul 09, 2012 11:26 am
127 to 141KW pre and post update for the H27 (or similar), so significant, but there's a bunch of changes. The "update" motors run a bigger exhaust, and I expect a bunch of other small things. The butterfly would require control from some inputs in the ECU, so it wouldn't be a bolt on - you'd require the ECU from the "update" 2.7 motor to get the increase. I suppose if you knew the conditions the butterfly opened at, you could use an aftermarket switch to control it, but I bet theres more than one parameter. (i.e it would be RPM+Throttle position, or RPM+MAP, not just RPM) There was a pre and post update H25 too. You can spot the later H25 cars - they have quite a fat exhaust tip with a funny bend right at the end. I don't know if the late H25 cars have the butterfly too. Steve.
Posted: Mon Jul 09, 2012 7:55 pm
I have the updated more powerful 2.5 with fully sick bigger exhaust
But it doesn't have the extra butterfly.
_________________ Chop Suzuki's are like Mogwai's, they multiply!
joeblow
Posted: Mon Jul 09, 2012 10:14 pm
......awwww
.....I like doing that...
_________________ builder of custom road legal zooks......and stuff.
stocker
Posted: Tue Jul 10, 2012 9:15 pm
So... Whats the Pipe Do?
Ultimately this is the question that needs answering
_________________ Stocker
Fatzook
Posted: Tue Jul 10, 2012 9:25 pm
Well clearly it does 2 things. 1. it balances the left and right plenums 2. it increases the volume of both plenums.
KEENSY85
Vehicle: 1985 lwb sierra UTE
Posted: Fri Jul 13, 2012 10:33 am
Keep going to post but learning to much ,its ok as long as ur sitting on the fence:)
_________________ Green? greeeen is nice !
bigrig91
Posted: Sat Jul 21, 2012 2:59 pm
So does this thing still run or is it broken???
_________________ 1997 Sierra, daily driver, 60mm coils, 2 inch body
atari4x4
Posted: Sat Jul 21, 2012 3:14 pm
i heard he was busy building for race wars with _noddy yeah yeah
bigrig91
Posted: Sat Jul 21, 2012 3:21 pm
Eff yeh. We all need NOS. Do you think the plenum mod he has done will help when he fits his NOS kit?
