It is currently Sun Nov 15, 2026 11:44 am
Vehicle: 1985 Holden Drover
Post Posted: Mon Jul 09, 2012 10:58 pm
Hey guys im just doing the timing belt/water pump/seals on the G13A at the moment and have a few questions.
My issue is that i followed the FSM and the Haynes manual setting the #1 piston to TDC by checking the dizzy making sure its at the right point and then lining up the keyway/notch on the crank sprocket. All is well until i got to the cam sprocket which is 180 degrees opposite to the notch.
Doing some searching i get a few different answers by different people, some of the results i found say that the crank points up and the cam points down and its all good the way it is... But then i find more results that say both should be pointed upwards?
Atleast the upside of the vitara i just my hands on, i dont have to rush with the sierra anymore Armsup
Thanks in advance guys!
1989 WT Sierra.
Post Posted: Tue Jul 10, 2012 11:47 am
Turn the cam so that both the No1 rockers are on the base circle and are loose... On the rock..
This will tell you if the mark goes top or bottom.
I can't remember off the top of my head.
Post Posted: Tue Jul 10, 2012 5:00 pm
http://www.outerlimits4x4.com/viewtopic ... iming+belt
Another thread from another forum describing what i see :lol:
1989 WT Sierra.
Post Posted: Tue Jul 10, 2012 7:17 pm
viewtopic.php?f=5&t=27871&p=498467&hilit=timing+no4#p498467
Post Posted: Tue Jul 10, 2012 7:30 pm
I see now! This is my experience with timing belts :lol:
So from what im taking from all this, how i have it now is correct with no1 at TDC. And if i spin the crank 360 than the cam spins 180 and no4 will be at TDC :)
Many thanks for the help guys!
1989 WT Sierra.
Post Posted: Tue Jul 10, 2012 8:03 pm
Yep... Cam turns at half speed of crank.
Post Posted: Tue Jul 10, 2012 8:28 pm
Thats what had me fucked, people refering to the sprockets as its timed to such and such a number!
Had it right all along :lol:
1989 WT Sierra.
Users browsing this forum: Google [Bot] and 24 guests
