| Author |
Message |
suzukikid
Joined: Sun Jan 14, 2007 10:30 pm Posts: 2803 Location: Melton Victoria!
 Posted: Wed Jul 11, 2012 5:47 pm |
Hey all i am getting chromos soon......but was thinking last night....
the cv breaks because it is the weakest link....right?
so what breaks if chromos are in there? hubs or diffs?
cheers
_________________ back in a built sierra!
Fatzook
 Posted: Wed Jul 11, 2012 5:49 pm |
Hub bolts, R7P's, transfer gears, maybe uni-joints. If you don't rape its ass offroad, then just about everything should be ok.
suzukikid
 Posted: Wed Jul 11, 2012 7:40 pm |
mmmmm sounds like i would rather do a cv! haha guess i will get some and see how they go! everyone swears by them....
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed Jul 11, 2012 7:44 pm |
I blew up a ring gear under a LOT of load that isn't of the norm.
Flogged it on lots of high traction surfaces without issue. 34's though, make sure your diff is up to scratch, be wary on the pedal.
_________________ mlm
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
Hub bolts. Take spares.
Steve
suzukikid
 Posted: Wed Jul 11, 2012 8:46 pm |
SierraDan wrote: I blew up a ring gear under a LOT of load that isn't of the norm.
Flogged it on lots of high traction surfaces without issue. 34's though, make sure your diff is up to scratch, be wary on the pedal. Im on 34s too.... and i seem to get frustrated when i cant drive something......and hit it harder and harder!haha Steve what does it do? blow the hub off? i have broken a standard cv and it took the hub with it! was thinkin a chromo would just distroy what is in there? only happened the once where the hub packed it in aswell.....but yeah
SierraDan
 Posted: Wed Jul 11, 2012 8:48 pm |
I meant with you. With 34's.
rpmwrx
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1303 Location: Geelong
 Posted: Wed Jul 11, 2012 10:06 pm |
Just because you are upgrading to chromos it won't mean that you will be invincible. I've broken a set of chromo's and your twice as crazy as me Nath... So good luck buddy...
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Thu Jul 12, 2012 6:45 am |
Get a solid pinion spacer made up when you install the chromo's
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu Jul 12, 2012 6:56 am |
I fitted CrMo's and subsequently broke a set of locking hub bolts(1), a rear uni joint(2), a rear ring & pinion(3)
1. Snapped all the bolts flush with the bearing hub, carrying spares wouldn't have helped as I couldn't remove the broken bits in the bush anyway.Pics in my build theread somewhere. I replaced all the Grade 8 bolts with Grade 12.9 and never had another breakage.
2. Rear uni snapped a trunnion but I doubt that was because of the CrMo's, just giving it heaps on a very steep rock face.
3. Rear ring and pinion had just had its day.
Fit the CrMo's and enjoy. Upgrade the hub bolts too.
birko
Joined: Sun Jun 07, 2009 11:30 pm Posts: 573 Location: Perth WA
 Posted: Thu Jul 12, 2012 7:00 am |
Yep, hub bolts, a pin punch or tiny chisel will help get them out in the bush. Check there tight before every trip
Gwagensteve
 Posted: Thu Jul 12, 2012 7:14 am |
want33s wrote: Fit the CrMo's and enjoy. Upgrade the hub bolts too. I'm going to disagree with this. We've all left our hub bolts stock. (although I think Dank has gone to studs rather than bolts) Our reasoning is that hub bolts are quick and easy to swap trackside - they're the easiest "fuse" to fix. We've had no trouble fishing out the broken bits with a pin punch/little screwdriver. If there was a meaningful upgrade in hub bolt strength, it might be enough to move the breakage point to somewhere that's not as easy to fix trackside, like a R&P. Even a uni is significantly more fiddle to change trackside than hub bolts. When we've done bolts we've been being pretty silly, so for us, in Victorian conditions, I think they break at about the right point. As an aside, those of us running floaters are using 12.9 unbrakos on the rear drive flanges and have had no problem with breakage. Oh - DONT APPLY LOCTITE TO THE HUB BOLTS - you won't be able to get the broken bits out on the track. Steve.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Thu Jul 12, 2012 8:40 am |
hey steve - how does a pin punch and small screwdriver get a hub bolt out? When i go crmo front i'll need to carry hub bolts and know how to get them out just in case!
also - where are you sourcing replacement bolts? i'd like to put fresh ones in when its first done so i know theyre all dandy.
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Thu Jul 12, 2012 8:58 am |
They snap clean of at the hub. So you have enough room in there to jag an edge with the punch and just tap it out enough till ya can get ya fingers on it or pliers.
christover1
 Posted: Thu Jul 12, 2012 9:15 am |
I've found with my Vitara that the driver is usually the weakest link. Could be true for other cars, too. Every time you go near a wreck, grab a handful of hub bolts. Never seen new ones, but they must exist. I've only ever broke one overtightening during assembly.
Gwagensteve
 Posted: Thu Jul 12, 2012 9:32 am |
sogone wrote: They snap clean of at the hub. So you have enough room in there to jag an edge with the punch and just tap it out enough till ya can get ya fingers on it or pliers. This. I thought it was going to be impossible, but it turns out they're not hard to get started. You can buy stud kits for toyotas pretty cheaply, but when we're at the wreckers we go on the scrounge. Steve.
alien
 Posted: Thu Jul 12, 2012 10:02 am |
ahhh ok, so you're just doing the door hinge chisel trick on a smaller scale =) haha
my mate works in nuts and bolts, if i ever remember i'll see if he can source me new ones - the stock ones are grade 8 yeah?
christover1
 Posted: Thu Jul 12, 2012 10:09 am |
I think its the cone shaped washers that are the hard to find bit, bolt looks just like any bolt.
Gwagensteve
 Posted: Thu Jul 12, 2012 10:46 am |
alien wrote: ahhh ok, so you're just doing the door hinge chisel trick on a smaller scale =) haha
my mate works in nuts and bolts, if i ever remember i'll see if he can source me new ones - the stock ones are grade 8 yeah? They're automotive grade 7, I've seen a comparison strength chart between JIS and "normal" grades but I can't recall the relationship now. Christover is right though, I'd the cone washers that are the difficult bit. Steve.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Thu Jul 12, 2012 11:05 am |
Ask benT were he gets the his bolts and come washers from.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Thu Jul 12, 2012 1:29 pm |
I like Steve's reasoning in having standard bolts as a 'fuse" so to speak, getting the weakest point out to where it is easiest to fix is a sensible approach.
SierraDan
 Posted: Thu Jul 12, 2012 1:57 pm |
I was speaking to a guy on the trip on the weekend in regard to patrols blowing hubs up. They're making drive flanges that won't break and drilling the hub bolts to save CV's and pinions
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Thu Jul 12, 2012 2:35 pm |
zooky08 wrote: Ask benT were he gets the his bolts and come washers from. From china I think.
suzukikid
 Posted: Thu Jul 12, 2012 5:11 pm |
i have a hand full of hub bolts here from when i brought the complete front for spares....
will get the cromos in a few weeks!
cheers guys!
suzukikid
 Posted: Thu Jul 12, 2012 5:24 pm |
actually while i still have you all.....
with hte chromos the hub end is the same spline count as stock?
and i got a rear here with a lockrite in it i housing and all i can bolt that straight in the front and im set?
zooky08
 Posted: Thu Jul 12, 2012 5:39 pm |
Yep if locker is a,rear one it'll go in the front with cromos. Nothing else doesn't need to be changed
suzukikid
 Posted: Thu Jul 12, 2012 6:15 pm |
sweet!
birko
 Posted: Thu Jul 12, 2012 9:58 pm |
From memory the Toyota stud kits are about $60 a side, not exactly cheap to buy 2 sets and 1 spare.
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Thu Jul 12, 2012 10:08 pm |
birko wrote: From memory the Toyota stud kits are about $60 a side, not exactly cheap to buy 2 sets and 1 spare. Last time I got some from Don Kyatt they were only about $1.80 a set of stud, cone washer, split washer and nut ? My wheel hub is too flogged out now after breaking them too often, so I ended up welding the free wheeling hub to the wheel hub, problem solved for now.
_________________ Made in JP. Built in WA.
birko
 Posted: Thu Jul 12, 2012 10:53 pm |
