It is currently Sun Nov 15, 2026 11:59 am
Post Posted: Sun Jul 08, 2012 8:22 pm
Hey guys, having a noob day
Ive done the rebuild on my wt case, right up to putting the last housing on. I dont want to fit it until i have fitted a right-angle threaded barb to the case for a breather hose.
My question is, does the "nipple" that is on these cases pop out at all? Looking from the inside it looks like it should, but i dont want to hack at it unless i know for sure.
Or do people just drill the hole out a bit and tap it from there?
Cheers all
By the way, im not talking about the breather cap
MY BUILD THREAD HERE!!!!!
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Jul 08, 2012 10:04 pm
Once you pull off the cap and the spring underneath it there is a small aluminium piece with the lip on it pulls out completely. It is a sort of force fit in the casing. After that is removed you can tap directly into the case.
Post Posted: Sun Jul 08, 2012 10:09 pm
sweeet, cheers mate. Ill attack it with a pair of vice grips in the morning.
Post Posted: Thu Jul 12, 2012 3:08 pm
why not knock it out from the inside with simmilar sized piece of metal?
Post Posted: Thu Jul 12, 2012 8:04 pm
because there is a deflector/casting in the way on the inside of the case. you don't have clear access to it.
Post Posted: Fri Jul 13, 2012 4:44 pm
what he said.
it stops the oil flicking up into the breather. was easy to remove with vicegrips, it gripped the soft metal well. i just wanted confirmation it actually came out, cos it practically destroyed it.
Users browsing this forum: No registered users and 36 guests
