It is currently Sat Aug 01, 2026 10:06 pm
Vehicle: Suzuki lj 80
Post Posted: Sun Jul 15, 2012 11:43 am
I have put an F10a into a Lj stockman, seams the stearing link rubs the sump, do i change the sump/cut it weld it or is it a engine mount issue?
Post Posted: Sun Jul 15, 2012 11:50 am
maybe hiway star can help you here
Post Posted: Sun Jul 15, 2012 12:14 pm
Use the F8a sump. :)
Post Posted: Sun Jul 15, 2012 1:17 pm
thanks, That was the first option, F8a sump had the same issue I suspect it was from a different machine - or engine mount issue, before i got it someone bashed the sump in - put a hole in it then filled it with devcon/putty.
Post Posted: Sun Jul 15, 2012 1:38 pm
Well... don't use that sump then. If you use an LJ sump use an LJ pickup too. Which steering arm BTW?
Post Posted: Sun Jul 15, 2012 3:10 pm
Can you post some pics of the mounts, also does it look like the mounts on the chassis have been rewelded (may have had a toyota or something in it at sone stage)
Post Posted: Sun Jul 15, 2012 6:18 pm
Definitely need pictures (engine mounts, steering, sump, etc). This "should" be a very easy conversion!
Clearance Hole Technology :P
Post Posted: Sun Jul 15, 2012 6:48 pm
I have put 16mm nuts under the engine mounts so the sump has a slight clearance to the drag link, the 16mm nuts lifted the engine 15mm, now the dizzy hits the bonnet its at a angle approx. 120 deg - and I assume it should have the adaptor plate from the F8a to make it at 90 deg. photos should be up.
Post Posted: Sun Jul 15, 2012 6:51 pm
it seams the sump is on backwards but the bolt holes only allow the sump to fit one way.
Post Posted: Sun Jul 15, 2012 7:01 pm
You need to use the F8 dizzy housing on the back of the head. You can see mine below, the dizzy should be pointing out the passenger side:
Old photo, you can see that the sump should have the drop on the front:
You have to use the F8 pickup as well. The bolt holes for the sump should line up..... :?
Post Posted: Sun Jul 15, 2012 7:16 pm
thanks for that, seams i have a few incorrect components - on both f8a and f10a for a lj
Users browsing this forum: Google [Bot] and 1120 guests
