Bruised wrote:
Idle up Solenoid it is. Pull out the green plug and killed the hunting.
Thank you ...
KEENSY85 wrote:
u learn somthing every day i allways thought that was called a stop flow solanoid
They are 2 different solenoids...
The idle-up solenoid is a vacuum switching solenoid that pulls on a vacuum actuator to turn up the throttle when you turn on headlights or a/c.
The idle solenoid / stop flow solenoid is there to stop the fuel and the engine running-on when the car is switched off.
