It is currently Mon Aug 03, 2026 8:37 pm
Vehicle: 1.3 Tin Top
Post Posted: Mon Jul 16, 2012 2:22 pm
I have had a minor water leak from the head for a while now so i decided to retorque all the headbolts and see if that fixed it.
Well after taking the valve cover off i was met with all but 1 rocker shaft bolts loose and one missing :shocked:
This is much like zookfans situation...
Rang around the usual part shops and none of them have any clue what a rocker shaft bolt was let alone if they had one in stock
i think my only option is to go to the bolt shop.
Does anyone know what the size and pitch of these bolts are?
Post Posted: Mon Jul 16, 2012 2:33 pm
6x10mm countersunk screw. Replace them with allen head screws so you can tighten them properly.
Post Posted: Mon Jul 16, 2012 2:36 pm
M6???
Post Posted: Mon Jul 16, 2012 5:41 pm
Got a few here if you can't find any.
Make sure you clean the holes with a solvent, then dry well, then use thread locking goo.
Centrepunch peen helps too.
Post Posted: Mon Jul 16, 2012 5:48 pm
Thanks ill get some later this week.
Im really surprised no damage was done... there was only one bolt on the back of each shaft that was actually tight.
Vehicle: 1985 lwb sierra UTE
Post Posted: Mon Jul 16, 2012 9:22 pm
little basturds are allways like that when ever i remove 1 of those roker covers
lol
Green? greeeen is nice !
Users browsing this forum: Google [Bot] and 72 guests
