It is currently Tue Aug 04, 2026 8:00 pm
Post Posted: Tue Jul 17, 2012 5:53 pm
hi all, i have a 92 sierra standard 1.3l, i was driving down the road in first gear, when it just cut out on me, i went to re start it and it wouldnt start, all it did when i turn the key is the starter motor makes one loud tick noise and then that is it nothing else. i have rocked it back and forward in gear and beaten the shit outta the starter motor, but it didnt do anything. any ideas off what could be the problem? thankyou.
Post Posted: Tue Jul 17, 2012 6:08 pm
Check the battery connections
Vehicle: Jimny 99 2" lift, 31s etc
Post Posted: Tue Jul 17, 2012 6:09 pm
Earth cable from block to firewall?
if u don't get stuck u ain't trying hard enough
Post Posted: Tue Jul 17, 2012 6:46 pm
Battery connections all good did think off the earth cable
Post Posted: Tue Jul 17, 2012 7:16 pm
Fuseable link?
Post Posted: Tue Jul 17, 2012 7:20 pm
Clicky starter, meaning Low volts to the coil?
http://zukioffroad.com/Tech_Library/starter_relay.shtml
Post Posted: Tue Jul 17, 2012 7:30 pm
It doesn't go click click click. It is just one tick and that's it
Post Posted: Tue Jul 17, 2012 7:34 pm
Jump the exiciter on the solinoid to the pos on the battery.
bye
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Wed Jul 18, 2012 1:39 pm
its happened to me before, it was the earth from the battery to the block. put your negative clamp on jumper leads on the negative terminal on the battery and the other end on the block and see if she starts, thats how you know if its your earth or not.
Users browsing this forum: Beery, Google [Bot] and 280 guests
