It is currently Sun Nov 01, 2026 8:49 am
Post Posted: Wed Jul 18, 2012 2:18 am
I've read they're different, what's the difference?
Something tells me the F8a one is designed for more high RPM power. :lol:
Is there any advantage in using an F8a cam in an F10a or vice versa? Has anyone tried it?
Thanks
Hayden
Post Posted: Wed Jul 18, 2012 9:13 am
Put them side by side.
If all the bumps are in same place,
and keyways etc are same, then it should work.
Never tried it myself, but thats what I do to decide on cams.
Post Posted: Mon Jul 23, 2012 8:04 pm
The firing order and the head are the same so I don't see why it wouldn't work/couldn't be made to work. I don't need to put in a new cam, I was just wandering if there were any performance gains to be had by doing so. :)
Post Posted: Tue Jul 24, 2012 6:58 pm
The difference is the f8a camshaft is designed different on the snout . It uses another housing bolted to the front of the head which houses the cam seal and uses a different rear timing belt case. As for performance , it has the same lift and duration as the f10a camshaft
Post Posted: Tue Jul 24, 2012 7:03 pm
Thank you very much! :)
Users browsing this forum: Google [Bot] and 453 guests
