It is currently Tue Nov 03, 2026 7:07 am
Post Posted: Sat Jul 14, 2012 5:08 pm
Hey guys, doing a 2.5l conversion into my vitara. Have a long motor 2.0l v6 with 116,000kms on it. DOES require a new water pump, timing chains sound good when it was removed. Would recommend a new sump gasket as it wept a bit as well. Before the motor was removed i drove at least 500kms and performed very well. Will have no accessorys so just sumps, block, heads, intake manifold etc
Will require the coil packs and plugs out of your motor and another sensor.
Chasing $800, located in redcliffe.
Post Posted: Wed Jul 18, 2012 7:03 pm
bumpy
Post Posted: Tue Aug 07, 2012 7:29 pm
BUmp...
Post Posted: Wed Aug 15, 2012 6:42 pm
Keen to move this out of my shed. Can get fixed up so its ready to drop in for $440 more. Price for motor is around $700 ish ONO
Water pump - $80
Timing Chain kit - $110
Labour - $250
Will still need sump gasket.
Call me on 0413244035 Cheers
Post Posted: Thu Aug 16, 2012 9:04 pm
$1100 bucks for a V6 with 116,000kms on it. New timing chain, water pump and sump gasket. Ready to bolt in. Need it gone.
OR $650 with good sounding timing chains, broken water pump and weeping sump gasket........
Post Posted: Mon Aug 20, 2012 2:02 pm
can deliver within reason. bump
Post Posted: Mon Aug 20, 2012 2:11 pm
If it was a 2.5 I'd be all over it...
Post Posted: Mon Aug 20, 2012 2:35 pm
Hahah i have one of them too. Need to sell this motor to fund my springs, hydraulic bump stops and the missus 21st present hahah.
Post Posted: Mon Aug 20, 2012 4:26 pm
Ok so its mostly to fund my girlfriends 21st present....As if buying her a house wasnt enough.....
Pics, Engine is apart at the moment as in pics but covered, ready for the timing chain kit etc to be done. Can reassemble if required.
Included:
Engine
Inlet manifold and accessories
Fan
Flywheel
Clutch
Box 'o' bits
Headers
02 sensors (not sure of condition)
Not included:
Powersteering bracket
The pulley that tightens the fan belt i think.
Post Posted: Sun Aug 26, 2012 12:00 pm
BUMPP
Post Posted: Mon Nov 26, 2012 9:00 pm
rebump. just listed on ebay
Users browsing this forum: No registered users and 20 guests
