ok i have a very anoying clunking sound at the rear of my sj50 when i go over some bumps.i have checked all the driveline and dont appear to have anything loose.also makes a clunking sound when turning at a average speed from the same area. DIFF ??????
OK so spent the day looking at every nut and bolt under the car.turned out the klunking was the rear exhaust bracket was bent and whenever it moved up and down it hit the mounting bracket.believe me i had done the SHAKE LIKE MAD THE EXHAUST but it had to move directly up and down .it also cured the turning at higher speed klunk.
Users browsing this forum: Google [Bot], JoshuaM95 and 255 guests
