It is currently Tue Nov 03, 2026 10:19 pm
Vehicle: suzuki sierra 1993
Post Posted: Tue Jul 17, 2012 4:50 pm
im just wounding does any body ever have problems with the carby on a 1.3 it revs a bit high i had it tunned and sounds like the
choke is staying on
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Jul 18, 2012 8:59 pm
disconect the choke and see what happens
Green? greeeen is nice !
Post Posted: Wed Jul 18, 2012 9:06 pm
usual causes are
1: dirt/water/crud in any or all parts of fuel system
2: old fuel pumps crap thier diaphragms and bits get stuck in carby
3: most sierras are very old, and reco carby is needed.
With my old Sierra, I cleaned entire fuel system, including tank,
then fitted a high quality long life inline filter (efi commodore I think)
A new fuel pump, and extra fuel filter after pump, and did a minor carby reco kit.
Never had a carby problem again.
A bit of metho in fuel once a month helps break up water, so it goes through better
Post Posted: Wed Jul 18, 2012 9:07 pm
X2
Chokes can play up if the water heating pipes block up,
or linkages wear or gum up.
Vehicle: 92 serra soft top
Post Posted: Fri Jul 20, 2012 12:49 pm
christover1 wrote:
X2
+ 1 that fixed my zooks high idle and excessive fuel drinking, the carbs water heating pipes where blocked, this causes the choke to stay shut and a high idle and rich running, before you go trying to tune it, make sure these water pipes are not blocked.
Users browsing this forum: Google [Bot] and 77 guests
