It is currently Wed Nov 04, 2026 8:40 am
Post Posted: Sat Jul 21, 2012 9:04 pm
hi all i was just wondering what is the difference in the g13a engine and the g13b? and how to tell the difference between them?
Post Posted: Sat Jul 21, 2012 11:25 pm
G13B is 1298cc, G13A is 1324cc (longer stroke, taller block) and the block will be marked.
The G13A will be 8v SOHC, the G13B can be 8 or 16V, SOHC or DOHC.
Post Posted: Sat Jul 21, 2012 11:54 pm
There's really 4 kinds of g13...
G13a - SOHC 8v (NT sierra, swift, barina) 1324cc
G13b - DOHC 16v (swift gti)
G13ba - SOHC 8v (swift, barina, WT sierra) 1298cc
G13bb - SOHC 16v (jimny, swift)
Theyre all pretty different!
You can tell what is what by the engine number - it will start with the engine type, ie: G13A.... or G13BA....
Vehicle: '94 suzuki maruti
Post Posted: Sat Jul 21, 2012 11:57 pm
how to tell the difference, looking at the left (passenger) side of the block, just in front of where the transmission attaches, there will be either G13A or G13B stamped on it... and you will be able to tell the difference between the SOHC and DOHC, if not, google images SOHC and DOHC, you'll pick it up easy after that.
Post Posted: Sun Jul 22, 2012 8:29 am
arighty then cheers for the info, another stupid question, but im still learning about this shorta shit haha, so i have a g13ba wt sierra if i was wonting to put a g13a or a g13b engine into how much and what would i have to change to make them fit? cheers.
Post Posted: Sun Jul 22, 2012 10:09 am
g13a - there's no benefit, its the same motor really.
g13b - search "GTI engine" as that's what theyre commonly referred to.
IMO - if you're keen on more power, just plonk a 1.6 (g16) in there - you have the choice of carby or efi - go EFI if you can.
Post Posted: Sun Jul 22, 2012 11:38 am
Alrighty then to put a g16 In it what would I have to change and how difficult would it be to do your self?.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sun Jul 22, 2012 11:50 am
I could do it my self, Alien could do it himself, but Im not sure you can just yet.
If your just learning, its a BIG job mostly because of wiring and fuel, unless you put in a carby G16 (dont).
Start on small projects before an engine change and work your way up to it,. ;D
Post Posted: Sun Jul 22, 2012 11:59 am
The g13 that I have in my Sierra is stuffed and on its way out.
Post Posted: Sun Jul 22, 2012 12:02 pm
neofitou wrote:
Alien could never do it himself, cos he's too lazy to learn how, and would rather just pay someone who knows what theyre doing to do it
fixed =)
Post Posted: Sun Jul 22, 2012 12:56 pm
Neofitou say don't fit a carbie 1600, I would be carefull who you take advice from.
Post Posted: Sun Jul 22, 2012 4:29 pm
okay then, how much and what would i have to change to put a carbie 1600 in my wt sierra?
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Jul 22, 2012 5:55 pm
I'm pretty shure that the block is not actually taller, the crank is molded different it is not hollow the 1298(g13b&g13ba) has a different moulding of the crank it is hollow and is better balanced,the cams are also different ,and the g13b was used as a gti block but also as a 8v combination
Green? greeeen is nice !
Post Posted: Sun Jul 22, 2012 6:31 pm
BenT kit and a plug on the vit carby changed
viewtopic.php?f=15&t=15009
Post Posted: Sun Jul 22, 2012 7:04 pm
so what all i would need is a bent kit? and aso wouldnt i need to change al the wiring and what not?
Post Posted: Sun Jul 22, 2012 7:28 pm
Most stuff plugs in exept for the plug to the carby. I did the conversion in one day and was very happy
With the result.
Post Posted: Mon Jul 23, 2012 5:22 am
AND the sump has to be changed to a sierra one and the oil pickup needds to be cut and welded.
Post Posted: Mon Jul 23, 2012 6:05 am
I didn't change the sump on mine and it didn't come close to the diff :wink: however my front diff is around 60mm forward from stock.
I won't be changing the sump on the G16b that I am putting into my lwb either
Post Posted: Mon Jul 23, 2012 7:19 am
Yes, but that's cos you're really special :thefinger:
Users browsing this forum: No registered users and 96 guests
