It is currently Wed Oct 28, 2026 12:53 pm
Vehicle: 2003 Jimny Auto
Post Posted: Mon Jul 23, 2012 11:26 am
Been reading lately about people making a manual switch they can press to lock up the torque converter in an auto tranny
Does anyone know anything about this and if so, what wire/s would be involved on my Jimny?
Post Posted: Mon Jul 23, 2012 11:33 am
Yeah I had this on My GQ patrol. It engages the solenoid that locks out the converter.
Post Posted: Mon Jul 23, 2012 11:35 am
http://www.automatictransmission.com.au/release.asp?NewsId=42068
Post Posted: Mon Jul 23, 2012 12:09 pm
Yep thats the setup i was reading about. I am wondering if my cars can be modded also... DIY
Post Posted: Mon Jul 23, 2012 12:24 pm
anyone done it to a AW4 before? sounds like a worthy mod 8)
Post Posted: Mon Jul 23, 2012 12:26 pm
AW4 should be easy, i ve reasearch it before but dont have the links at work.
Post Posted: Mon Jul 23, 2012 8:40 pm
This would be a good addition, just got to remember to turn it off. :lol:
Post Posted: Tue Jul 24, 2012 9:56 am
/\ /\ Yes... or it will get VERY expensive very quickly.
Post Posted: Tue Jul 24, 2012 10:06 am
With Transfer case gearing lowered,
I no longer feel the need for a converter lock up on down hills.
Post Posted: Tue Jul 24, 2012 12:35 pm
Why should it get expensive?
Running with the torque converter locked IS a normal operating mode - the TC on my AW4 spends more of its time locked than it does unlocked - as far as I can tell the biggest problem you'll face if you manually lock it and forget to unlock it will be stalling the engine when you come to a stop, pretty much the same as if you forget to depress the clutch with a manual transmission.
Post Posted: Tue Jul 24, 2012 1:08 pm
Leave the converter locked and stall the car.
Then put it in Park, restart the car and put it in Drive without unlocking the converter and see what happens.
Post Posted: Tue Jul 24, 2012 1:19 pm
Yeah the clutch for torque convertor lock up aint big enough for too much load
Post Posted: Tue Jul 24, 2012 8:32 pm
I can see how that could hurt...
But anyway, i think i woud opt for a momentary switch, where you can hold it to lock the TC just the times when you want it.
That said, I dont know that my 1.3l petrol motor has that much engine braking anyway, perhaps a manual jimny driver can comment on that. Do they crawl down hills in low low?
Also I suspect that 1st gear is taller in an auto as well.
Post Posted: Tue Jul 24, 2012 8:36 pm
Jimny.. Crawl :lol:
Without reduction of some sort Jimnys have crap low range.
Post Posted: Tue Jul 24, 2012 9:01 pm
Thx dan :(
Vehicle: LJ20 LJ50
Post Posted: Tue Jul 24, 2012 9:42 pm
Then set up a relay off the park/neutral switch that would disconnect the lock up. problem fixeded!!!
Camels have nice toes
Post Posted: Tue Jul 24, 2012 11:50 pm
It would be interesting to try I reckon, if all it is is a switch hooked in to the solenoid, the cost is near zero... I reckon it would be useful for me.
I'd love if someone on here knows where the wire is. I have a multimeter though so I guess I can go chasing. But who has the time :roll:
Post Posted: Wed Jul 25, 2012 9:47 am
Then what happens when you put it back in drive again? Convertor locked again. Problem un-fixored :P
Lil Foot!
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Wed Jul 25, 2012 10:29 am
Wouldn't a simple latching relay circuit with a momentry action switch solve this problem?
Katherine 2013!
Vehicle: LJ20 LJ50
Post Posted: Wed Jul 25, 2012 10:14 pm
No the problem was fixoreded you moroeon. You make it so its push button so it has to be re engaged. Jezz what would you know about wiring. Sounds like you have a degree in cuzz-tec circuitry :thefinger: :thefinger:
Users browsing this forum: Google [Bot] and 319 guests
