Joined: Fri Nov 06, 2009 10:30 pm Posts: 385 Location: Kapiti Coast, New Zealand
Vehicle: Samurai G16, DMax.
Posted: Thu Jul 26, 2012 3:24 pm
I've just picked up a J20 powered 4 door GV. getting the SV420 ready for sale. If I dont get my asking or near to it, I might part it out. In my dreams the stock diff heads might be swappable. Anyone know? Also I have the TSOR petrol tank protector on the SV and after a rough measure up it looks like it will swap too. Anyone??? I know the front bar and snorkel wont swap:(
Joined: Mon Aug 13, 2007 11:30 pm Posts: 1787 Location: Butler, WA
Posted: Thu Jul 26, 2012 4:36 pm
The SV diffs will bolt straight into the GV, but the front GV diff has vacuum actuated crap so you wouldn't be able to fit that to the SV without doing something to it.
Why do you want to swap them, do you have lockers fitted to the SV already?
Posted: Thu Jul 26, 2012 7:58 pm
Yep, should've added that I have an ARB in the rear of the SV so if the diff ratios are the same I'd rather swap it over. I'll be looking for a steel front diff. Thanks for that.
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
Posted: Fri Jul 27, 2012 11:08 am
If the gv is a J20 manual it will have 4.8 diffs. If its auto it will have 5.12. If i was you i would swap the diffs over (front and back) and get rid of the air front diff. you will also have to fit manual hubs if you do this.
If your planning on going bigger tyres you will want to do diff gears anyway if its a manual.
Posted: Sun Jul 29, 2012 4:55 pm
B4T Thanks for the help. Its already on 235 70 16s and I dont want to go any bigger. I might put a suspension kit in it but I'll use it a bit before I do anything significant. Steve.
Users browsing this forum: No registered users and 122 guests
