It is currently Sat Oct 24, 2026 2:53 am
Vehicle: 1991 suzuki sierra softtop
Post Posted: Thu Jul 26, 2012 10:18 pm
hi i bought a suzuki sierra 1991 model (1.3l) and it has 31 inch mud tyres on it.
i am looking to get it to go alot slower for some offroad work as low range is a bit too fast sometimes and have been told that putting a 1.0L transfer case is a good way to achieve this. im basically just looking for some opinions and advice on this modification. i have the transfer case and also front and rear diffs which i was also planning to put in to lower the gearing. how would this affect my topspeed as well? ill probly have a ton more questions hopefully this will help some people out.
oh yeah this is also largely because i dont want to destroy my clutch as well.
Post Posted: Thu Jul 26, 2012 10:58 pm
Hey mate.
Just go straight for 4.9 or 6.5 transfer gears and leave the diffs alone. Its a tried and true solution.
Post Posted: Thu Jul 26, 2012 11:09 pm
Hey mate.
X2
Only need to change the diff ratios when you can't get enough high range reduction from the t-case gears.
Post Posted: Thu Jul 26, 2012 11:11 pm
is this ridzilla's sierra?
Post Posted: Fri Jul 27, 2012 3:16 pm
hey
not sure who ridzilla is sorry dude maybe i bought it off him
fatzook i have a welded diff and need a rego inspection so i need it removed
monley i guess the transfer case would be enough. how would it go on the highway if i did both though?
Post Posted: Fri Jul 27, 2012 3:22 pm
just go 6.5s and ya done bloke....see if ya get picked up on rear diff....if ya do put ya rear one in and get the roady then put the welded back in.... ya cant go wrong
back in a built sierra!
Post Posted: Fri Jul 27, 2012 3:38 pm
venny wrote:
hey
It would be doing more rpm @100kph than what it needs to be doing. You may need to do both if you went 33s+ but 6.5s and 31s it will be fine on road. What sort of terrain do you drive?
Post Posted: Fri Jul 27, 2012 4:13 pm
at 100 on 31s you will be doing about 3600 you dont need to go any lower
Users browsing this forum: No registered users and 129 guests
