It is currently Fri Oct 23, 2026 11:04 pm
Post Posted: Fri Jul 27, 2012 9:40 am
How do you remove the dowels from the block when doing a 1600 conversion?
Post Posted: Fri Jul 27, 2012 10:03 am
pliers/multigrips/vice grips. twist and pull
Post Posted: Fri Jul 27, 2012 10:16 am
look it up on youtube there are a few ways
Post Posted: Fri Jul 27, 2012 10:27 am
I've given it a good go but they are stuck in there pretty good.
Post Posted: Fri Jul 27, 2012 10:31 am
vice grips and a hammer maybe? none i have removed have been that tight
Post Posted: Fri Jul 27, 2012 10:47 am
Mine was stuck really good, I wouldnt recommend this way but I slowly drilled away at it until it was almost gone then I spilt it using a small chisel, be careful and you won't damage the block
Post Posted: Fri Jul 27, 2012 11:01 am
Use a drill slightly larger than the inside of the dowel. Drill slow and it should grab it and spin it out.
Lil Foot!
Post Posted: Fri Jul 27, 2012 11:51 am
I don't have a drill.
Post Posted: Fri Jul 27, 2012 12:36 pm
Well then use the methods above but I hope you don't have to reuse the dowels.
Lil Foot!
Vehicle: LWB Sierra & XL7
Post Posted: Fri Jul 27, 2012 2:05 pm
WHAT !!! 8O
Well best you go and buy one, They're really handy for drilling and making holes in shit.
'92 Vitara & Camper trailer
Vehicle: 4wd
Post Posted: Fri Jul 27, 2012 2:47 pm
What do you mean by dowel? The stud that's threaded in or the bush type thing that's pressed in?
Watch out or you'll get sued.
Post Posted: Fri Jul 27, 2012 3:48 pm
The piece of round tube. The studs where easy.
Vehicle: 4wd
Post Posted: Fri Jul 27, 2012 3:56 pm
I'd use an ezy out.
Vehicle: chick magnet coily
Post Posted: Fri Jul 27, 2012 4:17 pm
use a heat gun/blow torch and heat up the area around it then use vicegrips/pliers
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Fri Jul 27, 2012 10:56 pm
Squirt in a couple of applications of some CRC days/weeks before you want to pull them out with Vise-Grips.
Post Posted: Fri Jul 27, 2012 11:31 pm
Invest in a good quality set of vice grips and if it's still hard to get out ask a local mechince if he can do it for you are you planing on reusing the studs or getting new ones??
Post Posted: Sat Jul 28, 2012 4:31 am
If Vise Grips don't work find an old bolt that JUST fits into the dowel.
Put a couple of spots of weld on the outer edge of the dowel where the it meets the bolt.
Turn the lot with a spanner.
If it won't turn, use a slide hammer on the bolt.
Post Posted: Sat Jul 28, 2012 11:27 am
If he doesn't even have a drill I'm doubting a welder Jas
Lil Foot!
Vehicle: 1.3 Tin Top
Post Posted: Sat Jul 28, 2012 11:44 am
just weld with 24v and jumper leads :rofl:
Post Posted: Sat Jul 28, 2012 12:18 pm
Maybe, maybe not.... I tend not to make assumptions like that..
Assumption is the mother of all fuckups. :wink:
Welding a bolt in would be an extreme case... Vise grips and hammer should pop it out.
Post Posted: Sat Jul 28, 2012 1:20 pm
They are really stuck in there. I think I'll get the old man to attack them with the welder.
Users browsing this forum: Google [Bot] and 115 guests
