It is currently Mon Oct 19, 2026 4:14 pm
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Sat Jul 28, 2012 8:57 pm
Just a quick question for the Suzuki gods. Can a jimny manual steering box fit into a wt Sierra? I think I have better chances finding a tight jimny box then Sierra? If they fit what model/year?
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Jul 28, 2012 9:10 pm
sorry to hyjack ur thread bud :-) i would realy like to know as well i know they do but bolt in or slight alterations? and is it true they help with a ruf?
Green? greeeen is nice !
Post Posted: Sun Jul 29, 2012 7:20 am
Bolt straight in. Pitman arm slightly shorter,about 7mm i rekon, so you can move front diff slightly futher forward.
Post Posted: Sun Jul 29, 2012 12:14 pm
X2
Bolt it in like it was made for it.
Shorter pitman arm is good for moving diff forward but bad for turning lock. It would pay to extend the stopper bolts in the felt seals so you aren't loading the box at full lock.
Vehicle: Sierra Ute '87 Sj70
Post Posted: Sun Jul 29, 2012 12:46 pm
cab you run a jimny powersteer box of a g16b?
It's all coming together Armsup
Post Posted: Sun Jul 29, 2012 1:55 pm
Can't see any reason it won't work.
Post Posted: Sun Jul 29, 2012 7:22 pm
So any manual jimny box? If I don't feel like moving the diff can
I just swap pitman arm?
Post Posted: Sun Jul 29, 2012 7:29 pm
couldnt u just leave the jimny one on shurly it couldnt affect it
Post Posted: Mon Jul 30, 2012 6:11 am
You don't have to move the diff... I'm not 100% but I don't think Sierra pitman will fit Jimny box.
How could a shorter pitman arm NOT affect anything?
Shorter pitman WILL reduce steering lock.
Longer pitman will try to increase it but stopper bolts in the hubs will prevent it. CV's can only turn so far.
Post Posted: Mon Jul 30, 2012 9:46 am
Have you contacted 4wd Products?, they did have brand new steering boxes reasonably cheap.
ph: 02 9631 1577
Post Posted: Mon Jul 30, 2012 12:48 pm
Jas we had a play with a Jimny steering box a while back on a Nt chassis and it didn't actually reduce the steering lock because the hub stop bolts limited the steering lock before the steering box ran out of turns. In does mean more turns of the wheel to achieve same result and in theory it should lighten steering a little due to the better mechanical advantage of being shorter.
Jas you are right, the splines are different from sierra and jimny so pitman arm is not interchangeable.
Post Posted: Mon Jul 30, 2012 3:40 pm
I have a spare jimmy manual steering box. Pm me if your intetested
Post Posted: Mon Jul 30, 2012 5:58 pm
Cool... Real tech info... Armsup
Post Posted: Tue Jul 31, 2012 2:16 pm
Ok awsome so it's a bolt in jobby! No changing pitman arms or moving diffs!
I'll contact 4wd products. But I'd rather a genuine box, unsure of the quality of an aftermarket item? Though I don't have experience in that stuff so I can't really judge the quality I guess.
Users browsing this forum: No registered users and 194 guests
