It is currently Tue Oct 20, 2026 12:54 pm
Vehicle: 85 Holden Drover, bit rough
Post Posted: Thu Jul 26, 2012 8:36 pm
i have a dent that goes from the front of the passenger side sills to the rear, and up behind the door. if i cut the sill out am i going to be able to get my hand up in behind it the pop it back out??????/
considering half the dent would be gone should pop out pretty easy
Post Posted: Thu Jul 26, 2012 10:08 pm
Only way you are going to get any sort of reliable answer is to post up some pics mate.
Post Posted: Fri Jul 27, 2012 8:11 pm
yeah havent got any at present that are any good. try to take some tomorow
Post Posted: Fri Jul 27, 2012 9:07 pm
If I have read it right, if you cut your sills like this you will be able to reach up inside the B pillar, there is a small piece of metal joining the inner and outer skin of the b pillar about 4 inches up from were I cut the sill and depending on the size and type of dent you may not get enough leverage to push the dent out by hand. If you remove the seatbelt retraction part from the inside of the pillar you may reach it using a hammer and block of wood if its further up the pillar.
Made in JP. Built in WA.
Post Posted: Sat Jul 28, 2012 3:37 pm
i tried uploading a photo but it says it too big. the dent runs along the sill then behind the door it gos up about 100 - 150mm or so
Post Posted: Sat Jul 28, 2012 4:43 pm
just leave it....chicks dig body damage
back in a built sierra!
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Jul 29, 2012 7:57 pm
just cover in ali
Green? greeeen is nice !
Post Posted: Sun Jul 29, 2012 8:36 pm
Please dont.
I love lamp
Post Posted: Sun Jul 29, 2012 9:52 pm
KEENSY85 wrote:
just cover in ali
Please be joking :shocked:
Post Posted: Mon Jul 30, 2012 8:17 am
im hopin thats a joke too.......
Post Posted: Thu Aug 02, 2012 8:28 pm
had thought about the old checker plate fix it
Post Posted: Fri Aug 03, 2012 4:34 am
Jfuit94 wrote:
had thought about the old checker plate cover up the rust behind it
Users browsing this forum: Google [Bot] and 211 guests
