It is currently Mon Oct 19, 2026 10:17 am
Vehicle: 1994 sierra soft top
Post Posted: Mon Jul 30, 2012 9:41 pm
Just wondering what needs to be done to run 31's on a WT sierra without to much rubbing ?
Post Posted: Mon Jul 30, 2012 9:50 pm
Cut off bumper outriggers
a bit of guard massaging with a hammer, or 2 inch bodylift
I love lamp
Post Posted: Mon Jul 30, 2012 10:19 pm
What will the rim size and tyre profile for just using the cutting the bumper and the guards method ?
Post Posted: Mon Jul 30, 2012 10:49 pm
15 rim and say 9 or 10.5 wide tyre. Not sure about rim offset but if you go to the tyre shop they will generally be able to tell you
I love lamp
Post Posted: Mon Jul 30, 2012 11:05 pm
I suppose we use 15x7 rims ?
Post Posted: Mon Jul 30, 2012 11:09 pm
you can do it by redrilling your spring perches back 1" and remounting the centre pin on the front leaves there (hence moving the diff 1" forwards - but check the steering doesnt bind!) - run a 1" driveshaft spacer, and hammer and cut the shit out of the guards until they fit without modifying the bump stops (if you don't like cutting the guards then you'll need to extend the bump stops). You'll also want to address the gearing!
15x7 king rims will be fine, pretty sure theyre a -13mm offset.
Vehicle: 1985 lwb sierra UTE
Post Posted: Mon Jul 30, 2012 11:21 pm
i fit 30s on my last suzi with a 2 inch sping lift and 2 inch body lift and i had shit loads of room left i could have easly fited 31s in maybe even bigger not shure
Green? greeeen is nice !
Users browsing this forum: DamoRed83 and 272 guests
