It is currently Tue Oct 20, 2026 3:31 am
Post Posted: Wed Aug 01, 2012 8:12 pm
Hello Guys,
I have been looking for hours on info fitting a g16B 2000 model twin coil pack engine into my 85 zook.
been offered a complete engine etc for $100
I think I have the correct info can people please confirm I have my info right.
1 Ben T fitting kit ( can I use something else?)
2 Modify Sump and oil pick up (do I use the 1.3 sump or the baleno one?)
3 use 1.3 starter flywheel clutch and gear box starter needs a little grinding
4 Change thermostat housing to clear fire wall
5 rad and coolant hoses moved and changed
6 need ecu speedo cluster wiring loom fuse and relay box.(lots of diagrams on the web)
7 fuel system swirl pot lift pump and high pressure pump
8 Exhaust manifold change use 1.3 pipes with g16b flange!
I understand there is lots of little things to do put is the the bulk of things that need changing?
Many Thanks Tim
Vehicle: SWB sj70
Post Posted: Wed Aug 01, 2012 10:10 pm
1. ben t kit
2. 1.3 sump, modify sump and shoten pickup
3. use 1.3 clutch flywheel starter, ben t kit = no starter cutting
4. will need to run a pipe from back of the motor up over the ehaust
5. correct
6.use the baleno speedo and graft into sieera cluster, lots of info
7. from what people have told me Tank>Vl pump>EFI filter>Fuel rail
8. Just get extractors
Post Posted: Wed Aug 01, 2012 10:38 pm
get a 1.6 EFI vitara starter. AFAIK the BenT adaptor kit does NOT allow for the fitment of a 1.3 starter, as the problem is block clearance.
You CAN grind the starter to make it fit however.
Post Posted: Thu Aug 02, 2012 4:31 pm
Petroworks also do a bellhousing adapter and unbreakable engine mounts.
I had them in Snow White... VERY good kit... Unbreakable mounts but not un-meltable :oops: I fitted a heat shield to the passengers side and had no more problems.
Users browsing this forum: No registered users and 182 guests
