It is currently Sat Oct 24, 2026 5:41 am
Post Posted: Thu Aug 02, 2012 12:03 am
Anyone have any suggestions what might be preventing a H27A motor from turning over by hand?
To cut a long story short....
- Purchased a H27A from over east
- Have stripped it down to do the timing chain on it before I install it
- Went to turn the motor over to so the keyway on the crank is facing upwards (ready to do the timing chain) but turning the crank clockwise it only turns ~45 degrees max before it comes to a very hard stop. Trying to turn it the other way does the same thing... goes about 45 degrees and stops solid.
There is so little movement in the crank that the pistons are barely moving 1cm if that. The keyway is currently facing downwards, goes about 20 degrees either way from that point. 2 pistons seem to be at the bottom of the stroke, 2 in the middle, 2 at the top.
The resistance is definitely not coming from the heads/valvetrain - it is the crank itself which is hitting against something. There are no abnormal noises, the bores look clean from what I can see, the rods look straight etc etc. There is no flywheel bolted on at the moment so the crank should be free to turn over. I've taken the plugs out also. Looking down the plug holes I can't see anything out of the ordinary.
Is there something I'm overlooking? Is there perhaps a magical bolt somewhere which locks the engine for in transit or anything crazy like that?
Has got me stumped. Is it possible the timing chain has skipped some teeth and the pistons are hitting against the valves? If that was the case the engine should still turn over the opposite way though shouldn't it?
Moses' SQ625 GV Pig
Post Posted: Thu Aug 02, 2012 12:47 am
FFS
Found the problem.
So pissed off right now. This was supposedly meant to be a running motor with no abnormal noises. Entire motor is probably trashed.
Moses' SQ625 GV Pig
Post Posted: Thu Aug 02, 2012 12:56 am
I can't find any info on whether the H-series motors are interference or not. I know the G-series and J-series are non-interference....
how have you checked the bores/ Rods?
Post Posted: Thu Aug 02, 2012 12:57 am
Snapped exhaust valve?
Post Posted: Thu Aug 02, 2012 1:00 am
Yeah H series are interference. And yep that is a snapped exhaust valve.
Moses' SQ625 GV Pig
Post Posted: Thu Aug 02, 2012 1:04 am
Heads off, and see what lies beneath. :?
Shitty news mate. :cry:
Post Posted: Thu Aug 02, 2012 1:06 am
They are???
I know the 8v G13s aren't, but I'm pretty certain the 16v DOHC G13B is and I'm under the impression that all the J series are.
As for the H series, I've no personal experience, but I've seen enough pictures of piston tops to conclude that they are.
If it's got four valves per cylinder, I wouldn't chance it.
Post Posted: Thu Aug 02, 2012 1:09 am
Yeah I forgot about the G13B. :roll:
Post Posted: Thu Aug 02, 2012 2:04 am
I've emailed the seller. It came from a wrecker with a 3 month warranty so will see what they say.
Very, very, very lame. Really wishing I had bought the other motor with less km right about now.
Time to drown my sorrows with a beer or ten. *sigh*
Moses' SQ625 GV Pig
Vehicle: Jeep
Post Posted: Thu Aug 02, 2012 4:46 am
What a bastard... they must have known it was like that... i hope they dont pull the old, " It was fine when it left us, must have happened in transit, or you did it... " BS... what a piss off... :(
Post Posted: Thu Aug 02, 2012 7:49 am
Bugger :( Hopefully they deal with it properly, and have access to an equal or lesser km engine!
Post Posted: Thu Aug 02, 2012 11:51 am
That's shit mate. Hope the seller looks after you.
Can't catch a break with this thing, can you?
Post Posted: Thu Aug 02, 2012 4:12 pm
Where did you end up buying it from mate?? i hope none of the ones that i recommended you i would feel terrible.
Post Posted: Thu Aug 02, 2012 7:19 pm
shite thats the worst thing that could of happened
hope the wrecker comes to the party
Post Posted: Thu Aug 02, 2012 8:02 pm
AZ lynch mob?
Post Posted: Fri Aug 03, 2012 11:34 am
Wrecker is arranging for the motor to be picked up today and is sourcing a replacement for me.
There may be light at the end of the tunnel yet.
Moses' SQ625 GV Pig
Post Posted: Fri Aug 03, 2012 11:37 am
good news, can wait to see this on the road 8)
Post Posted: Fri Aug 03, 2012 2:26 pm
Nothing like doing a good half days work for absolutely no gain. :roll:
POS boat anchor is back together and on the crate again.
Off to the post office now to pick up my KOH 2011 & 2012 DVDs. The day can only get better from here 8)
Moses' SQ625 GV Pig
Post Posted: Fri Aug 03, 2012 3:20 pm
And beer, don't forget beer
Post Posted: Fri Aug 03, 2012 5:53 pm
that sucks mate, its a pretty big screw up to. hopefully the next one is better.
Post Posted: Fri Aug 03, 2012 6:25 pm
Nah it wasn't mate, was one I found in gumtree which just happened to be a wreckers. Mistakes happen though, as long as they come good with a replacement motor (one that works preferably :lol: ) I'll be happy enough.
New exedy clutch just rocked up as well which was the last thing I was waiting on. I wonder if its a pretty pink one like the ones they use in their adverts.
PS: King of the Hammers 2012 DVD is awesome 8)
Moses' SQ625 GV Pig
Post Posted: Fri Aug 03, 2012 6:32 pm
How much the motor cost, how much mileage it got on it?
helloo
Post Posted: Fri Aug 03, 2012 6:38 pm
Was $1900 plus delivery and had 103,000km on the clock supposedly.
Moses' SQ625 GV Pig
Post Posted: Fri Aug 03, 2012 6:40 pm
i'd like to know how you snap a valve 8O
Post Posted: Fri Aug 03, 2012 6:50 pm
oh thats good to hear. What is this king of the hammers you speak of. Googleing now.
Vehicle: Jeep
Post Posted: Fri Aug 03, 2012 7:10 pm
Well that is good news, glad they came to the party on it, and will sort it out for you ! :D
X 2 8O
Vehicle: 2003 Jimny Auto
Post Posted: Fri Aug 03, 2012 7:32 pm
What a shit. Nothing like the letdown of a long awaited toy not working when you unwrap it. Like a chick who gets her gear off then wont perform
Post Posted: Fri Aug 03, 2012 7:37 pm
hey ninja any idea what the shipping weight was for the complete H27a?
Post Posted: Fri Aug 03, 2012 7:44 pm
Courier dude said it was around 80kg when he dropped it off mate, not sure how accurate that was though. That was minus the flywheel and accessories, so just the long motor plus intake/injection.
Freight costs from over east ranged from $200 to $600, with the majority of them (ie. all but two) being between $500 - $600.
Moses' SQ625 GV Pig
Post Posted: Sat Aug 04, 2012 1:12 am
From what I've been told the heads are attached to the stem by friction welding - they apparently hold the head stationary and bring the rotating stem into contact with it - and defective welds do happen.
This came about during a discussion about a "dropped valve" (which is pretty much the same thing as what I see in the picture - the head is missing) on a G13B DOHC, except that this one happened at high rpms, resulting in the complete destruction of the #3 piston - we took the head of the valve, and the remnants of the piston out of the oil pan.
Users browsing this forum: No registered users and 400 guests
