It is currently Sat Oct 31, 2026 2:12 pm
Vehicle: Grand Vitara
Post Posted: Fri May 08, 2009 3:14 am
It's so trivial I almost didn't post, but then I thought about the days of pondering where to put the rotten thing!
For some time I've run the CB with velcro on it, simply stuck to the back of the rear set (folded forward) placing it over the centre console. I've taped the aerial to the seats and used a ciggy lighter plug to get power from one of the sockets. That's pretty non intrusive, but it's also very temporary.
Since I hate doing anything that can't be undone when I want to sell the car, it's been the cause of a lot of angst!
Several owners have their CB's simply velcroed to the passenger side of the transmission tunnel, but that doesn't do it for me.
The answer came when I managed to find a ridiculously cheap Uniden with a remote mic control, (a one-off special from www.ryda.com), I paid about a third of the GME equivalent, so I'm pretty happy.
The dash panel under the steering wheel is easy to get off by simply removing three screws. If you stand on your head and look waaaay up against the dash, you might even see the fuse panel. I had to ask the dealer where it was! :oops:
Anyways, under that plastic there's a metal beam which is just right for providing a rigid connection for the set, I just made a simple aluminium bracket to mount it off (the black bit). The mic exits under the steering wheel and mounts on the dash with double sided tape hard against the console and high enough so that the cord just hangs below it.
Mounting the antenna was another problem. There are so many folds in the skin of the thing that there isn't anywhere a folded bracket will fit round the bonnet. I thought of poking a hole in the roof for a while, then the simple solution turned up.
It's probably marginally legal even with the nifty bit of body trim, as it could be a danger to pedestrians, but since mounting it I've found a spotlight bracket at SuperCheap in Aluminium for around $70.00. It's got a neat little bar in front of it, and has two holes, so I can get a 3G phone antenna too if I want! :D I suspect that will happen shortly!
Sorry to bore you with such minutiae but if it helps someone down the track...or if I can pick up a suggestion or two then that'd be terrific!
Cheers,
P
[url=http://sunshinecoastdaily.blogspot.com/] Suns
Post Posted: Fri May 08, 2009 2:08 pm
Looks good. I mounted my UHF radio using the rear view mirror and map lights mounts. I fitted the antenna to the driver side mud guard using the under bonnet bolts.
The trivial things are the good things.
Post Posted: Sat May 09, 2009 1:58 am
im gonna ge aremote head uhf and mount the face panel in the flip up compartment below the radio. the mic is detachable and when not in use will go in the glovebox. the main body will mount up under the dash somewhere. havent thought mush yet about the antenna but the numberplate bracket might be the go.
Ill post up pics when i get around to doing it.
Post Posted: Sun May 10, 2009 11:25 pm
Have a look atthese bars, Supercheap have them as well if you want to view one, they are probably more legal than my mount.
I looked and looked at that little glove box mount thing, I reckon it's a good alternative.
Cheers,
P
Post Posted: Sun May 10, 2009 11:39 pm
played about with the radio today and im gonna mount it in the armrest/center console. Im using a tx3600 with the detachable remote face. ill post up a pic when its mounted.
Post Posted: Sun May 24, 2009 7:29 pm
Ok i finally got around to fitting the uhf to the 08 GV. the radio i used has a remote head which has made it a bit easier to fins a position for it. I mounted the head inside the center console under the arm rest. and the main body up under the glovebox. there is a bit of room once the plastic panel is removed and once connected the panel is clipped back into position. Can't even tell its there. The reason for putting the head under the arm rest is when not in use the UHF is not seen. only had to drill one hole in the bottom of console to get the interconnecting cable out.
antenna will mount to front numberplate.
Users browsing this forum: No registered users and 16 guests
