It is currently Sat Oct 17, 2026 12:38 pm
Post Posted: Tue Aug 07, 2012 4:33 pm
FOR SALE
93 Suzuki JX 5dr vitara
Rego till October with RWC, 1.6 efi manual, p/s, a/c (regased and working) 274,000km on body.
Original g16b replaced with Late model g16b out of suzuki baleno (120,000km) due original motor failing. Injectors and fuel pressure reg fitted from baleno manifold.
Fitted with all new engine seals, water pump, timing belt+idler and tensioner pulley, new drive belts, radiator hoses, heater hoses, genuine Suzuki thermostat, excedy clutch, rear brake wheel cylinders, pbr front brake pads and machined rotors. full service: oil+filter, air filter, fuel filter, spark plugs, coolant, driveline oils, brake fluid.
Full interior strip out and clean, full under body rust proofing (done with no gearbox or exhaust fitted for full coverage) all work done less then 5000km ago. I am a mechanic by trade & built this car up to use myself but now working away so don't have the time to use it which is reason for sale.
Also fitted with extractors, 2inch lift+upgraded shocks, sunraysia wheels with maxis mud tyres, cd player, roof racks, towbar, recently replaced front wheel bearings and radiator.
Good vehicle, lots of work done - inspection will not disappoint.
Located in Pomona (30mins from Noosa) QLD
$5,700
Ryan 0413 764 859
I am listing this for a mate so please dont PM me as its not my car.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Users browsing this forum: No registered users and 60 guests
