It is currently Sun Sep 20, 2026 12:57 am
Vehicle: Suzuki sierra
Post Posted: Wed Aug 01, 2012 7:32 am
My oil sump has been leaking for a while now so I put a new sump gasket in.also my main seal has been replaced not long ago.but there is still an oil leak around the sides and bottom of the gearbox.any ideas what this might be.
Post Posted: Wed Aug 01, 2012 8:34 am
Rear main again
Sump not sealed properly
Gearbox input seal
Gearbox input casing not sealed right
Small plate on back of motor leaking
Vehicle: 4wd
Post Posted: Wed Aug 01, 2012 8:44 am
Also check dizzy seals. When they go oil runs down the back or the motor.
Watch out or you'll get sued.
Post Posted: Wed Aug 01, 2012 9:27 am
I've been.its been doing this for a while now.ive checked my oil levels and I'm not loosing any.when I had the sump leak could there be oil in the gearbox housing and the fly wheel flicking the oil out.
Vehicle: 1985 Holden Drover
Post Posted: Wed Aug 01, 2012 9:35 am
Are you sure it's not old oil from beforehand?
1989 WT Sierra.
Post Posted: Wed Aug 01, 2012 9:47 am
Gearbox input seal
Post Posted: Wed Aug 01, 2012 9:54 am
I'm pretty sure its not.it's been doing it for a while,so I'm sure the old oil would have gone by now surely.
Post Posted: Wed Aug 01, 2012 9:57 am
clean it. take it for a blatt, and see if the oil leak comes back
Post Posted: Wed Aug 01, 2012 10:03 am
Can I clean it without taking the gearbox out.it won't hurt it if I spray decreased in the housing.
Post Posted: Wed Aug 01, 2012 11:09 am
At it. Not in it. Try to avoid the electrics as well
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Aug 01, 2012 5:17 pm
look at were ur shifter bolts also the prevouse might not have bolted the shifter plate up properly and might be spashing out
Green? greeeen is nice !
Post Posted: Wed Aug 01, 2012 5:33 pm
It's coming from inside the gearbox where the metal plate cover is,that covers your fly wheel. And it's definitely engine oil
Post Posted: Wed Aug 01, 2012 6:14 pm
Rear main seal. That's a gearbox out job to replace.
Post Posted: Wed Aug 01, 2012 6:50 pm
pretty easy job for ya 30min ether way
Post Posted: Wed Aug 01, 2012 7:02 pm
Ok thanks mate.
Post Posted: Wed Aug 01, 2012 7:04 pm
It's been doing it for a while but I'm not loosing any oil
Post Posted: Thu Aug 02, 2012 6:52 am
If you weren't losing ANY oil you wouldn't have a leak, would you?
Even one tablespoon of oil is enough to make a mess but not enough to notice down on the dipstick.
Engine oil coming out of the bottom of the bellhousing is a leaky rear main seal as has been said a few times already.
Post Posted: Fri Aug 10, 2012 11:58 am
i rekon its the rear main seal.... anyone else?
MY BUILD THREAD HERE!!!!!
Vehicle: LJ20 LJ50
Post Posted: Fri Aug 10, 2012 12:04 pm
rear main seal :deadhorse:
Post Posted: Fri Aug 10, 2012 12:11 pm
Users browsing this forum: Google [Bot] and 64 guests
