It is currently Sat Oct 24, 2026 11:14 pm
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Aug 18, 2012 8:23 am
Can anyone give me a steer in the right direction to get this off
To get to this...
There's some clunking etc back there and that oil leak looks like it could have something to do with it :(
Thanks guys :)
Post Posted: Sat Aug 18, 2012 9:12 am
You will need to remove backing plate, 4 bolts behind and disconnect handbrake cable and brakeline and put the wheel back on and give it a good tug, axle should come out. Making sure car is stable first of course. Wheel bearing is probably shot, should probably do both sides.
Post Posted: Sat Aug 18, 2012 9:42 am
Cheers mate! Any other suggestions for pulling the axle out? Doesn't seem to want to budge :( I'll do both sides and pull the diff centre too and get the air locker fitted while it's all out :)
Post Posted: Sat Aug 18, 2012 9:47 am
If the car is PROPERLY SUPPORTED lie on the ground and give the wheel a good kick.
Vehicle: Yellow Ute
Post Posted: Sat Aug 18, 2012 10:35 am
Or just get the longest extension you have and slip it between the backing plate and diff housing and tap on the end.
Post Posted: Sat Aug 18, 2012 3:46 pm
Chuck a spare rim or hit your current steely with a rubber mallet. It won't take long before it comes out. The four bolts on the backing plate will also need to be undone :-)
Post Posted: Sat Aug 18, 2012 4:28 pm
viewtopic.php?f=17&t=19477&hilit=chain+puller
Post Posted: Sat Aug 18, 2012 4:34 pm
Got it out with a slide hammer :) bearing is fucked! So now to chase up some bearings etc and someone to press off and on for me... Fun times :(
Post Posted: Sun Aug 19, 2012 12:15 pm
Is the gear for the abs sensor reusable? A few people have been telling me that it would be needed to be cut off along with the bearing and new ones pressed on? Doesn't sound right to me and none of the bearing kits seem to come with a new one???
Post Posted: Tue Aug 21, 2012 6:24 am
The speed sensor ring/gear will be reusable. I cannot see why not, unless it looks damaged. I think from memory it has spots of weld holding it, so they will be cut/ground first of course, then pulled. I am pretty sure heating with a blow torch will expand the ring and bearing to allow removal.
Use an engineering sealant to reseal the backing plate. Clean the old sealant properly without gauging the surfaces.
Post Posted: Tue Aug 21, 2012 8:27 am
Yeah theres no welds on it, just waiting on bearings and then I've got someone to press it all for me :)
Users browsing this forum: No registered users and 429 guests
