It is currently Tue Oct 27, 2026 9:38 am
Post Posted: Fri Jul 13, 2012 7:57 am
A few blokes were asking me about the mounts on my recent WT case conversion as they are a black rubber rather than the orange poly ones that were originally handed out in the kit. Obviously ORA have changed what they are using, but I found them today elsewhere if anyone wanted to change to the softer ones to eliminate some noise.
http://www.jimnybits.co.uk/shop/jimny/j ... d_598.html
EDIT
Ooops,
Looks like ORA sell them on their own too, look the same though as JB's
http://www.offroad-armory.com/store/ind ... uct_id=378
What they look like
MY BUILD THREAD HERE!!!!!
Vehicle: 07 vvt jimny
Post Posted: Mon Aug 20, 2012 8:47 pm
anyones using these? do they quieten down the transfer?
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Aug 20, 2012 8:56 pm
I'm using them, can't say that my transfer was noisy to begin with... However! the old mounts were showing signs of wear at around 30,000kms, and I'd already broken a stock bracket once, so when I replaced the brackets with the ORA ones (and I highly recommend doing it!!!) I got the better mounting blocks too.
The only thing I'll say if you do replace them is not to over tighten them like I did, and have the bolt pull all the way through :oops:
Post Posted: Mon Aug 20, 2012 9:03 pm
ME obviously....
and yes, they work. although i dont have anything to compare them to previously. +1 to Timmy's comment
Users browsing this forum: Google [Bot] and 214 guests
