It is currently Tue Oct 27, 2026 6:41 am
Post new topic Reply to topic  [ 542 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
Vehicle: Suzuki Sierra
Post Posted: Sat Jul 14, 2012 9:10 am
So these will bolt up on a Sierra?
How will they go for rim clearance?
Builder of street legal bacon sandwiches
Post Posted: Sat Jul 14, 2012 5:25 pm
Hey mate, what would the road behaviour of these be like. Also, rally style off road racing events? I know nothing about these or the way they drive but it seems like they wouldnt be very smooth? Would they handle 4wd high racing?
Post Posted: Sat Jul 14, 2012 5:26 pm
Polar_Bear wrote:
Armsup
Where do i sign up? 8)
Straight to the funny quote thread :rofl:
Post Posted: Sat Jul 14, 2012 7:47 pm
out of curiosity, why choose chain over cogs? im assuming its a cost thing in that chain us easily sourced and doesnt require machine time or hardening?
Post Posted: Sat Jul 14, 2012 8:11 pm
I missed this earlier, but on re-reading:
Are you back to an off the shelf CV for these instead of the uni-jointed drive-shafts?
Trying to keep track of the componentry (for a 1.6 Vit, staying IFS):
- Diff = either GV steely or your custom steely? 26 spline side-gears only?
- Axels = stock + stub + adaptors, or your customs?
- CVs = something mysterious off the shelf or custom uni shafts?
===PORTALS=== (incorporating strut, tie-rod, balljoint and caliper mounts?)
- F.W. Hubs = standards?
So looking at that it's very much a discreet system, we can't pick bits and pieces to suit?
(eg - I'm unlikely to be able to afford the portals, but I'd love a stronger CV option.)
All very cool regardless ;)
Post Posted: Sat Jul 14, 2012 8:48 pm
Vitaras struggle to fit bigger than a 31 in their wheel arch. 33's fit with some guard and firewall chopping, but how will the extra 90mm track width effect guard and firewall clearance with such a dramatic increase in scrub radius?
Post Posted: Sun Jul 15, 2012 9:47 pm
I don't like the idea of using straight cut gears. The gears for the chain will have to be machines and hardened anyway. Plus I can save a lot of room by going to chain.
Post Posted: Sun Jul 15, 2012 10:00 pm
This will be an option but not required.
If you wanted to ugrade the front diff yes. But not rquired.
The outer CV will be changed for a new shorter version (splines) and then the portal bolts on.
Unless you go my solid shafts you only replace outer CV with an off the shelf item as above.
Struts do not change or move, tie rods do not move, brakes moved down with stub axle.
I'm mainly doing the tailshaft front for vehicles without portals. I'm not getting ahead of myself here as it's only in the planning stage.
Scrub radius etc I'm not sure about yet but the model has been changed to suit the Ramsey silent chain system.
New height increase........67mm....was 83mm.
New track increase......52mm (each side)....was 86mm.
Gearing still at 1.3:1
Post Posted: Sun Jul 15, 2012 11:50 pm
Well 52mm track increase has brought it back within the realm of big offset wheels, which people have been living with for ages, so that sounds promising.
Post Posted: Mon Jul 16, 2012 5:46 am
Just depends on wat the rim size and offset has to be to clear the portal
If u could clear it with 16 x7 10p u should be right more then that and they are going to be way out there
Post Posted: Mon Jul 16, 2012 12:36 pm
Thanks for the answers JB.
Will definitely be up for a pair of shafts (plus spare) when they are done.
Otherwise looking forward to progress. :goodjob:
Post Posted: Mon Jul 16, 2012 10:09 pm
New style smaller box. Just waiting on some chain CAD to come through.
Post Posted: Mon Jul 16, 2012 10:15 pm
something like these could bring the sparkle back on the old silver princess. 8)
Post Posted: Wed Jul 25, 2012 2:00 pm
this wont make the front of a vitara flex any better tho. just give it a big lift and clearance
Post Posted: Wed Jul 25, 2012 2:03 pm
helloo captain obvious
Vehicle: 1999 Jimny
Post Posted: Sat Jul 28, 2012 12:57 pm
Possible to portal the later GVs Joe???????????????????? :shocked:
Post Posted: Sun Jul 29, 2012 1:13 pm
These look like a 2 gear design portal so I was wondering how you planned to reverse the direction of drive at the wheel
Post Posted: Sun Jul 29, 2012 1:20 pm
Plan changed to a chain drive,
so direction stays same with 2 gears/pulleys.
Thats how I understand it?
Post Posted: Mon Jul 30, 2012 10:42 am
Personally, I'd be looking at the twin chain. The additional width could possibly add a little too much load on ball joints however the added security of the load sharing would be an advantage.
Post Posted: Mon Jul 30, 2012 1:51 pm
[quote="atari4x4"]helloo captain obvious[/quote
was the point for SAS not to make the front flex better?
Post Posted: Mon Jul 30, 2012 2:14 pm
No. Portals gives you better groud clearance under diffs.
Suspension type and geometry affects flex.
EDIT: oops misread that,
Post Posted: Mon Jul 30, 2012 2:58 pm
The point of the sas was to get stronger cvs not big ramp flex
The portal will offer stronger axels and cv and gear reduction for larger rubber
If the strut can handel it
And if u can get a small enough rim to fit then this is going to be great
Ps if this fits a vit then it might fit a coily to as they run the same hubs
Post Posted: Mon Jul 30, 2012 10:20 pm
... and we're not talking about SAS anymore...
Vehicle: 1999 Jimny
Post Posted: Tue Aug 07, 2012 3:33 pm
This question /\
Post Posted: Tue Aug 07, 2012 9:05 pm
The plan is to flow on to other vehicles. Just waiting on some gear to come from the U.S.
Post Posted: Wed Aug 08, 2012 8:40 am
Any idea of rim size and offset needed to clear these
Vehicle: 1999 Jimny
Post Posted: Sat Aug 18, 2012 4:46 pm
After today I will be waiting with baited breath, so gotta stop it scratchin it's belly!!!!!!
Post Posted: Mon Aug 27, 2012 6:58 pm
The plan is to have any wheel fit it, from standard offset to aftermarket.
I looked at a cnc machining centre today that would make these easy......the wife even said yes 8O ..........I'm running out of real estate though!
Post Posted: Mon Aug 27, 2012 7:45 pm
8) 8) 8) i wonder how many hours you'll spend cooped up in the shed then!? haha
Post Posted: Mon Aug 27, 2012 7:48 pm
move the wife & kids into the shed & take over the house?
Users browsing this forum: No registered users and 18 guests
