It is currently Thu Sep 24, 2026 5:20 pm
Post Posted: Mon Aug 27, 2012 7:23 pm
Hey guys my sj50 is running wellish now I drove if around today a fair bit for the first time since the convo.
The problem I have is the car drive like its not advancing the timing it's real laggy then picks up with big revs. It slso struggles to get to a 100 in 4th gear.
Is there a timing jumper or grounding in the ecu ? And does some one no what pins they are ? Or what the process is ?
Vehicle: SJ51T
Post Posted: Mon Aug 27, 2012 7:35 pm
Sounds like the same problem i had when i Did my gti conversion the first time. Under no load I could rev the motor like it was running perfectly, but under load I had to get above 4k ish to get it to move nicely. Turns out I had a dodgy AFM. Did you fiddle with the diagnostic port at all?
Post Posted: Mon Aug 27, 2012 7:48 pm
Well I'm not 100% sure, I sort of went into this a bit bla-zay, I cut the whole loom up and only left what I needed. So I yeh guess I did fiddle with it haha
What pins are they in the ecu?
Vehicle: SJ51T
Post Posted: Mon Aug 27, 2012 8:24 pm
Ahh I don't remember. When I'm on a Computer later tonight I'll look it up on my wiring diagram. I wonder if you accidentley locked the timing. Look for a violet/green wire and make sure it isn't grounded somewhere.
Vehicle: SJ51T
Post Posted: Tue Aug 28, 2012 9:01 am
A6- violet ( check eng light)
A11- violet/green (ground this wire to lock timing)
A19- violet/red (dunno what this does)
A24- violet/yellow (ground the check error codes with check engine light)
B13- violet/ white (dunno what this does).
They are the data lines. If you do chopped these out; wire them back in.
Post Posted: Tue Aug 28, 2012 9:46 pm
Afm man afm... Cleaned it up and bam!! Running mint put the jumper in to set the timing runs Awsome now love it
Cheers for the help man!
How's your fuel issue
Post Posted: Tue Aug 28, 2012 10:14 pm
Double post my bad
Vehicle: SJ51T
Post Posted: Tue Aug 28, 2012 10:29 pm
YAY! good to hear!Lucky you didnt have to replace your AFM; I had to.
ahh still having problems.. new pump is going in tomorrow, hopefully that fixes it.
Users browsing this forum: Google [Bot] and 142 guests
