It is currently Wed Sep 23, 2026 8:58 am
Vehicle: 1992 vitara
Post Posted: Tue Aug 28, 2012 5:36 pm
will i need reduction gears if i run 31's on my 92 vit and where do i get them and what$$$$$$$ am i looking at???
cheere
Post Posted: Tue Aug 28, 2012 5:43 pm
reduction gearing for vitara's will only effect low range due to the design of the transfer case.
http://www.lowrangeoffroad.com/
Post Posted: Tue Aug 28, 2012 5:47 pm
so going down hill will be shit?
Post Posted: Tue Aug 28, 2012 6:10 pm
Yes but so will going up hill and on straight road, that includes taking up from lights and general driving will deteriate.....as long as your in high range.
as soon as you move that second lever into LOW range, the reduction gears will then take effect and reduce your drive ratio giving you extra awesomeness :D it depends on the type of terrain that is driven, if a lot of sand driving will be done then reduction gearing is not advised unless you like to drive sand in 5th low range and reving the engine to redline. You could use high range but because of the 31's you will need to use a fair amount of clutch to start moving and will have less torque to keep you moving.
The gearing availible is really one sided. as in, it only really helps if rocky terrain is the predominant terrain because the reduction is so great (134% over standard to be exact), so this will mean that 5th low will be about the same as 1st in high.
hope this helps
Users browsing this forum: Google [Bot] and 192 guests
