It is currently Sun Nov 01, 2026 12:13 am
Post Posted: Thu Aug 30, 2012 9:55 pm
A motorbike cop pulled alongside me today and said my exhaust was illegal because it points out the side.
I've got a 91 WT Sierra with a vit 1.6. I had a 2" exhaust put on years ago that was straight out the back but fumes were bad so I had it changed to point out the side.
The thing is, I'm pretty sure it pointed out the side originally.
Anyone know what's standard and what's legal.
Post Posted: Thu Aug 30, 2012 10:11 pm
The rule used to be that you could have an exhaust exit the side of a vehicle 40mm past the rearward most opening window.... which on a soft top sierra, is the tailgate. It must exit on the passengers side and face down at a particular angle ( which I cannot recall ).
Given that the OEM sierra exhaust points to the side, I would have told him to go hit google images up before he shoots his mouth off next time.
Post Posted: Thu Aug 30, 2012 10:38 pm
The way I read this is that your exhaust points out side before tailgate which is not legal. If that is the case be happy that he was good enough to warn you and not give you a defect notice.
Post Posted: Thu Aug 30, 2012 10:54 pm
Cop must be pretty switched on and know his ADR's
10.1.2 the exhaust outlet, if to the side of the vehicle,
must discharge to the right hand side of the vehicle and
downwards at an angle to the horizontal of not less than
15 degrees and not more than 45 degrees; and
This rule I believe is to protect pedestrians on the side-walk from fumes/backfires etc. Beats me how vehicles can be approved or imported with exhaust discharging from the left hand-side when they obviously violate the ADR above.....
Post Posted: Thu Aug 30, 2012 11:17 pm
Have a look at your compliance plate. Does say it meets ADR10?
Post Posted: Sat Sep 01, 2012 8:45 am
Why don't we sort out where the guy's exhaust actually exits before busting out ADRs and the usual AZ speculative BS?
thericho, where does your exhaust exit? From your description it sounds like it's the same location as stock, in which case the copper is wrong.
Did he defect you for it?
Post Posted: Sat Sep 01, 2012 8:58 am
You are right Damo, it needs to be clarified, I read it as out the side like in front of the back wheel but as you say out the side could actually be out the back then pointing sideways like a stock exhaust.
Post Posted: Sat Sep 01, 2012 7:45 pm
Sorry guys - to clarify it sticks out the back, a touch further than the tailgate, exiting left, passenger side, with a slight downward inclination at the end.
Copper just gave me warning, I said it exited left when it was stock but didn't push it because there were other things he could have called me on. Just wondering because I prefer it like that and don't want to change unless necessary.
Vehicle: 1999 Jimny
Post Posted: Sat Sep 01, 2012 7:56 pm
If it was made from factory like that, bugger all the bronze can do.
Post Posted: Sun Sep 02, 2012 9:40 pm
Pretty sure it's the same as stock but fatter
Post Posted: Sun Sep 02, 2012 10:13 pm
Stocker
Mine used to come straight out the back, but faced 45' down. Helped a lot with fumes. But was also efi
Vehicle: Clown Car..
Post Posted: Mon Sep 03, 2012 1:02 am
Post Posted: Mon Sep 03, 2012 11:45 pm
Fair call! These are old pics but the exhaust is the same
Post Posted: Tue Sep 04, 2012 12:23 am
Thats close enough to where the OEM pipe exits for it to be a non-issue.
The cop may be right when applying the rules to any old car, but in this instance, he was/is wrong, as that is the OEM position.
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue Sep 04, 2012 3:01 am
I think the traffic just wanted to say something,
Post Posted: Tue Sep 04, 2012 7:48 pm
Your exhaust looks fine i reckon, if you want to be real picky the stock one in pic does end up exhausting slightly backwards but yours is pretty close to standard exhaust direction. Print that standard pic and keep in your car in case he pulls you over again.
Post Posted: Tue Sep 04, 2012 8:26 pm
^^^ what he said^^^
Post Posted: Tue Sep 04, 2012 8:30 pm
Does it have a number plate light? Is it just blurred out with the plate?
He coulda done you on that if not. Red reflectors on the back?
I suspect you are right with the there being other things he could have spotted in a 30 second walkaround.
He was just pissing on posts. Wanker.
Post Posted: Tue Sep 04, 2012 9:15 pm
Fatzook can u check ur pms :rofl:
Post Posted: Tue Sep 04, 2012 10:05 pm
Thanks guys - sounds like he's just throwing his weight around. I'll get a pic to keep in the car in case he's local and has another go.
Post Posted: Tue Sep 04, 2012 10:51 pm
Why? Is there supposed to be a PM there that I need to read? :?
Post Posted: Wed Sep 05, 2012 2:11 am
Sorry mate just trying to catch up with u about getting my perches welded on, thought u might not have checked ur Pms :(
Post Posted: Wed Sep 05, 2012 2:57 am
Got no PM's from you here. Pm me with your questions.
Post Posted: Wed Sep 05, 2012 3:29 am
Pm sent
Vehicle: Coil Sierra
Post Posted: Fri Sep 14, 2012 8:26 pm
I had my exhaust moved to point out the LH side with a slight pitch down because the fumes were putting us asleep, the guy who welded the new tail pipe section on said its always been illegal to point any exhaust to the nature strip/foot path. I can see this being a good argument at main roads with OEM specs.
Vehicle: Daisy
Post Posted: Mon Sep 17, 2012 4:30 pm
So how do all these lads get away with the truck stack style tailpipes you see driving around on luxes and patrols e.t.c.?
Post Posted: Mon Sep 17, 2012 4:39 pm
it's luck of the draw & i'm guessing the OP getting away without a defect was simply due to passing the simple attitude test.
Users browsing this forum: Google [Bot] and 478 guests
