It is currently Tue Oct 27, 2026 4:57 pm
Post new topic Reply to topic  [ 542 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18, 19  Next
Vehicle: 1999 Jimny
Post Posted: Thu Sep 06, 2012 10:57 am
Well you can add me to the list for GV portals when ya ready!
Post Posted: Thu Sep 06, 2012 12:21 pm
I'm one step closer...............Think I bought a CNC machining centre today :shocked:
Post Posted: Thu Sep 06, 2012 2:39 pm
http://www.rocky-road.com/kickworks.html
will be interesting to see what the 'rockfather suspension' kit's high angle cv's are like
Post Posted: Thu Sep 06, 2012 2:52 pm
Thats been in the works for like 6 years or something stupid like that
Post Posted: Thu Sep 06, 2012 8:03 pm
haha well dont i look silly
Post Posted: Thu Sep 06, 2012 9:54 pm
You got so much cool shit in that shed that you're starting to lose track of what's actually there? :lol:
Post Posted: Thu Sep 06, 2012 11:23 pm
Woo Hoo !!
Post Posted: Sat Sep 08, 2012 8:14 am
Now if u can come up with a road legal rear steer to go with the portals that would be great
Vehicle: 2004 SQ625 GV
Post Posted: Mon Sep 10, 2012 4:37 pm
It will be wicked to bolt on the portals for the weekend and then during the week take them off and let the missus drive to car to work. Love It!!!!
Post Posted: Wed Sep 12, 2012 4:22 pm
Will be none of that. Once they are on....they are on. A different off the shelf CV is needed for the portals and the rear will be a full float based axle with discs, once it is changed it is changed.
The CNC....
Post Posted: Wed Sep 12, 2012 4:26 pm
ahhh the old fanuc tape centre model d. :lol:
what does it do? :?
Post Posted: Wed Sep 12, 2012 4:31 pm
It allows me to sit on my arse and talk shit to Kenn more often while getting some actual work done :beer:
Tape center is a bit missleading, it will be run via a pc with Solidworks/Solidcam.
Post Posted: Wed Sep 12, 2012 6:08 pm
Caution, Bat E more O dwarf? :lol:
Post Posted: Wed Sep 19, 2012 1:44 pm
Sad :(
Vehicle: 1999 Jimny
Post Posted: Thu Sep 20, 2012 8:35 am
it should be still decent to drive, all reports on other fourbies were pretty good to drive still.
Post Posted: Fri Sep 21, 2012 5:51 am
With the ratio in the portal I take it the diffs will be diff ratios.
Will the standard mounting arms handle the extra torque generated by the portal, looks to be secured with only 4 bolts
Vehicle: 1999 Jimny
Post Posted: Fri Sep 21, 2012 9:54 am
the shear pressure required to snap those 4 bolts would be huge..
Post Posted: Fri Sep 21, 2012 10:42 am
4 bolts are all that hold the rear wheels on... The 4 bolts hold on the rear drum assembly on a GV that the wheels are bolted onto... so I can't see it being any different.
Post Posted: Fri Sep 21, 2012 10:45 am
Also, stop spamming Joe's thread! He needs to stop reading the spam and finish the GV bars!!! :lol: Are they ready yet Joe??!!
Post Posted: Fri Sep 21, 2012 3:02 pm
True but the are axially aligned. Portals are obviously axially offset thereby generating different torsional forces, especially in 4wd terrain where the front tyres have a lot of horizontal impact forces from hitting rocks and bumps and also the forces required to get the front to drive vertically up obstacles.
Post Posted: Fri Sep 21, 2012 3:08 pm
Bit more to this then maybe you know. I'm sure Joe has considered these points but hey you feel free to hassle him in a tech thread
Vehicle: 1999 Jimny
Post Posted: Fri Sep 21, 2012 6:26 pm
Feel free to correct me but a 10mm bolt ,I think it was 8.8 grade has a shear pressure of 680MPa (92,000 psi) so I'd say a 12mm bolt???( not sure what size holds all the zook shit together) would be adequate to hold all the portals in position.
Post Posted: Fri Sep 21, 2012 6:54 pm
Problem is in an axial alignment the load is even spread as the load is applied in the middle of the bolt arrangement in this offset the load MAY pivot about one bolt, I know the shaft is there but it's not the typical force application, hence if the force pivots on one bolt the load applied to the others is amplified. Now I haven't done any work on this, I am just posing the question.
Vehicle: 1999 Jimny
Post Posted: Fri Sep 21, 2012 8:16 pm
Pose all ya want bud because unless it's written in moron I'm fuckin lost :rofl:
Post Posted: Fri Sep 21, 2012 8:34 pm
When I get the machining centre running and can make a mock-up I will be adding a bottom brace. Won't know anything intil I can get one bolted to a front end. Rear diff brace is easy.
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Oct 10, 2012 8:45 am
The CNC....
What programme does that cnc run..? Is it Mazatrol at All? How many tools, it looks like some kind of mill yer.
Post Posted: Wed Oct 17, 2012 5:09 pm
Looks like a 10 tool mill :lol:
Post Posted: Wed Oct 17, 2012 5:12 pm
cunting & weeding usn't wun uf keensy's stwong pounts
Vehicle: 1999 Jimny
Post Posted: Thu Oct 18, 2012 9:26 pm
WTF??????? Is that drunkeneese?????????
Post Posted: Thu Oct 18, 2012 10:41 pm
i think he is trying to be a kewi? have some fush n chups?
Users browsing this forum: No registered users and 13 guests
