It is currently Sun Jun 14, 2026 7:23 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
Post Posted: Tue Aug 31, 2010 3:00 am
this is how i fix clicky starters
pull the solenoid trigger wire off the starter solenoid
use a normal 30/40 amp relay and earth it to the battery and using 40amp or better
power string run power from the battery to the relay and then from the relay
to where the trigger wire usually lives on the starter.
then use the old starter trigger wire as the trigger for the relay.
then wrap a bit of tape around the relay to keep the smoke in and cable tie it to something.
and then hay presto, ya starter now works properly. :D ( dont forget to trim the cable tie so it looks like a professional job :wink: )
Post Posted: Tue Aug 31, 2010 4:09 am
you rough bastard
what's the go with the poxy electrical tape
Vehicle: MY2019 Jimny
Post Posted: Tue Aug 31, 2010 4:16 am
It has magikal properties!
Post Posted: Tue Aug 31, 2010 4:44 am
exactly. :wink:
but the real reason is i couldn't find my crimping pliers and the crimps are dodgy as.
Post Posted: Tue Aug 31, 2010 5:17 am
exactly. :wink:
Have thay been crimped?? :? :?
Tape won't hold em in, for long..
Post Posted: Tue Aug 31, 2010 5:51 am
they have been crimped however i used my fishing crimp pliers and they are a bit different to trizity crimps.
if i was worried i would have just soldered the crimps on. :wink:
Post Posted: Sat Sep 04, 2010 8:53 am
the auto elect did this with mine to just a little bit neater works a treat
Post Posted: Sat Sep 04, 2010 9:04 am
I'd fucking hope so! peaceout
Vehicle: jimny
Post Posted: Sat Sep 04, 2010 11:50 am
shep, good work and im surprised you lashed out on new tape, considering evrything else was from the dump!!!
Vehicle: Nissan
Post Posted: Sun Sep 05, 2010 2:31 am
he found the roll of tape at the dump :wink: :lol:
:goodjob:
Pearce-toff Racing
Post Posted: Sun Sep 05, 2010 2:56 am
:goodjob:
the blackfellas call the dump miter 11 :lol:
Post Posted: Sun Sep 05, 2010 6:28 am
so does that dickhead landlord of mine
Post Posted: Sun Sep 05, 2010 6:33 am
maybe you should ask mad kenny to "dispose" of him for ya :wink:
Post Posted: Sun Sep 05, 2010 7:10 am
he is too big to feed to a snake.
Post Posted: Sun Sep 05, 2010 7:58 am
thanks shep.
Something cheap and easy I can do in the meantime.
Post Posted: Fri Oct 29, 2010 1:43 am
What do you mean "clicky"?
My Starter occasionally makes a high pitch grinding noise and doesn't engage. It's probably not the same thing, but if it is and a fix as simple as this works you will have made my day :D
Post Posted: Fri Oct 29, 2010 1:49 am
i believe the clicky starter issue is when you turn the key you get a click and nothing else,
the noise your describing sounds like the starter solinoid on its way out.
Post Posted: Fri Oct 29, 2010 9:57 am
Sounds like your ring gear has a chunk out of it.
Post Posted: Tue Feb 08, 2011 7:52 am
dumb question - but how does rewiring it fix it? whats the actual cause of the clicky starter??? I just assumed the starter motor itself was on its way out?
Post Posted: Tue Feb 08, 2011 7:57 am
old wiring not supplying enough juice
Post Posted: Tue Feb 08, 2011 8:21 am
ahh i see... well, thats not the issue on mine cos the wirings not that old... bugga!
Post Posted: Tue Nov 15, 2011 7:02 am
my starter has started clicking again so doing the relay fix gives ya about 15 months extra life out of a starter.
if i get time this weekend i will share stage 2 of how to dodgy a starter motor. :wink:
Post Posted: Tue Nov 15, 2011 7:40 am
Can also be the battery not giving enough power to the starter. With the extra voltage drop of the stock wires with a half flat battery it can be enough to not get anything from it.
Post Posted: Tue Nov 15, 2011 9:19 am
I have a few of those spare shep herd.
Post Posted: Tue Nov 15, 2011 9:22 am
i have a vitara starter motor that i will be fitting soon :wink: :D
Post Posted: Tue Nov 15, 2011 9:23 am
Cause your keeping the auto aren't ya, ya crafty Lwb clown.
Ps. I'm jealous.
Post Posted: Tue Nov 15, 2011 9:45 am
Ps. I'm jealous.
yes i am 8)
Vehicle: 1985 Holden Drover
Post Posted: Tue Nov 15, 2011 10:19 am
Crap same as mine then, any chance of overhauling or getting just a new solenoid and not a whole new starter?
1989 WT Sierra.
Vehicle: 92 serra soft top
Post Posted: Mon Sep 10, 2012 8:01 pm
My zook had this done over 12 months ago but now every now and then i get nothing from the starter motor no click nothing just silence. Might be time for a new starter :deadhorse:
Post Posted: Mon Sep 10, 2012 8:09 pm
Pull it apart and see if you can just clean up the solenoid
Users browsing this forum: Google [Bot] and 106 guests
