It is currently Wed Nov 04, 2026 3:09 pm
Vehicle: After info
Post Posted: Fri Sep 14, 2012 8:52 am
Hi all I am in need of some dimensions for a 98 swb 3 door vitara. I am told that it is a SV420 or widetrack version.
I am building a A-Frame for a elderely person who is a long way from me and I cant find the dimensions for the distance between chassis rails and for any hole centres that might be in the front chassis rails. I am hoping someone here can help.
Post Posted: Fri Sep 14, 2012 3:43 pm
where are you located im sure someone could bring a car around for you to measure
Vehicle: After info
Post Posted: Fri Sep 14, 2012 3:57 pm
I'm in Shepparton, Victoria. I have looked around town for one but can not find one.
Post Posted: Fri Sep 14, 2012 3:59 pm
i have one in my front yard, with no bumper attached... i'll try & get some pics & measurements for you over the weekend.
Vehicle: After info
Post Posted: Fri Sep 14, 2012 5:06 pm
Thank's your a legend. My only other option was a really long trip.
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Sep 14, 2012 5:54 pm
Here is 1 found on google
Vehicle: After info
Post Posted: Fri Sep 14, 2012 6:02 pm
Thanks I found that one it gives me the distance between the rails but I also need hole centers on the rails and rails height and width.
Post Posted: Fri Sep 14, 2012 6:03 pm
I ll keep looking for u :)
Post Posted: Fri Sep 14, 2012 6:10 pm
that isn't a SV420 chassis
Post Posted: Fri Sep 14, 2012 11:40 pm
Could be an SE, everything looks familiar but I can't really make out the details, especially the front.
Vehicle: vits
Post Posted: Fri Sep 14, 2012 11:43 pm
Isn't the SV620 the same as theSV420 at the front? You might find one of these locally to measure up.
Post Posted: Fri Sep 14, 2012 11:45 pm
front control arm mounts/front body mounts tell me it's an SE :wink:
Post Posted: Fri Sep 14, 2012 11:46 pm
yeap, they're identical in regards to front chassis measurements. 8)
Post Posted: Sat Sep 15, 2012 12:18 am
Yeah, but looks more like a LWB - the shorties have a tubular front crossmember that I can't make out in the pic. The dimensions would help if they were legible.
Post Posted: Sat Sep 15, 2012 3:08 am
Top corner of the drawing says Tracker - if I assume that it was taken from a Chevy/Geo Tracker manual, that would make it an SE series chassis. Trackers were SE416 upto 1999 when the SQ series chassis was released - there was no SV series Tracker.
Vehicle: After info
Post Posted: Sun Sep 16, 2012 1:08 pm
Thanks for all your replies am still looking for dimensions (There hard to find). I have been looking into these A-Frames for towing car's behind RV's and there seems to be a lot of interest in them. I would like to get a catalogue of Mounting Bracket for various models if any one can send me dimensions and pics for any small car that is commonly towed I would be happy to pay $20 for each set of accurate one's, you can email me at stacyhall72@gmail.com if your interested.
Of special interest to me is the Vitara's, Grand Vitara's, Jimny, Sierra plus cars like the daihatsu terios etc.
Post Posted: Sun Sep 16, 2012 1:32 pm
Sorry Hally, I forgot... this vehicle is fitted with a 2" bodylift, but the bumper mounts are unchanged apart from an extra hole in the chassis horn for my bull bar.
I get 848mm outside & 758mm inside of the chassis "horns"
Top bumper mount
Lower bumper mount
Shape of Chassis Horns
I forgot to take one with the bumper on. :oops:.
Let me know if you need any other info.
Vehicle: After info
Post Posted: Sun Sep 16, 2012 2:28 pm
You have been a great help if I can get just a couple more dimensions I should be all set.
Post Posted: Sun Sep 16, 2012 3:15 pm
sorry about the average photography... need a third hand. :?
i get 45mm wide
from the flat surface to the body mount is 120mm
then the wider section for the lower bumper mount starts forming at 130mm
70mm deep
250mm high
Vehicle: After info
Post Posted: Sun Sep 16, 2012 3:50 pm
That's fantastic I think I have everything that I need. Thank you very much for your help and time it is very much appreciated. I should have no problem designing a Mounting bracket with everything you have given me. Again thank you for all your help.
Users browsing this forum: Google [Bot] and 74 guests
