It is currently Fri Oct 30, 2026 10:28 am
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 8:25 am
Just wondering how I can restrict my steering so my 30".tyres stop scrubbing up my chasi?
Thanks again guys your help is greatly appreciated! :D
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 8:34 am
Btw I don't even mind if u just link me to another thread if there's a good one on this :P
Post Posted: Mon Sep 17, 2012 9:32 am
buy bigger offset rims.
Post Posted: Mon Sep 17, 2012 9:42 am
I had 33x12.5 tyres on a vit and they only scrubbed a little on the guard. Rims were 15x8 -13 offset
Post Posted: Mon Sep 17, 2012 9:51 am
pretty sure that wasn't the question :roll:
that vitara was pretty modified before you got it, old mate had done a heap of clearancing to get 32's to fit.
Mr Charles Brown,
You can adjust the steering stops by the steering box, one is on the pitman arm & the other is on the chassis located in the right hand front corner of the vehicle, both are visible from underneath.
Thanks
Mr 4x4
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 10:27 am
Yeah I would like some off set rims...got some cheap ones? :P
Thanks Atari that was what I was looking for! Is there a thread showing how to do this? Thanks
Post Posted: Mon Sep 17, 2012 10:37 am
nah no thread, just turn the wheel to the left so it's just off the chassis rail & look up at the steering box & wind the bolt out til it's touching the stop, then do the same for the RHS
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 10:39 am
Okey dokey ill give it a go when I get home thanks again for your help mate!
Post Posted: Mon Sep 17, 2012 10:40 am
U might need longer bolts or just weld a nut on the end of the bolt
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 2:45 pm
Ok so I got home and had a look and are these the bolts you are talking about just making them tighter (move into the middle of the car) to lessen the maximum turn?
thanks =D
Post Posted: Mon Sep 17, 2012 2:50 pm
Nope, they are tie rods. Look at the pitman arm that is attached to the steering box.
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 3:23 pm
When u say steering box do u mean the power steering cos I don't have it :P sorry I'm a noob
Post Posted: Mon Sep 17, 2012 3:28 pm
No, if you look at the front of the chassis rail on the driver's side you will see a funny looking thing with a shaft going into the top of it and an arm on the bottom of it. This is the steering box, the arm on the bottom is the piman arm.
Post Posted: Mon Sep 17, 2012 3:57 pm
Steering box...
Post Posted: Mon Sep 17, 2012 3:59 pm
jas beat me... :oops:
stolen from lowrange's website
bottom right is the pitman arm & one of the steering stops, the other is chassis mounted
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 7:48 pm
Okey dokey thanks guys, found it (well I'm 99% sure =P ) attached to the chasi, is this the nut you tighten here in these pictures? (sorry had to use a torch under the car so they are crappy quality)
Post Posted: Mon Sep 17, 2012 8:16 pm
yes! undo the nut, wind the bolt out. tighten the nut.
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 8:29 pm
ok so winding the bolt out will lessen the amount the wheels can turn? =P thanks!!
Post Posted: Mon Sep 17, 2012 8:35 pm
bingo Armsup
Vehicle: Vit
Post Posted: Mon Sep 17, 2012 8:53 pm
im on a roll !!! :P thanks guys I'll try getting onto it tomorrow :D
Users browsing this forum: No registered users and 344 guests
