It is currently Mon Oct 19, 2026 5:24 am
Vehicle: jimny 3"jb lift 235/75/15
Post Posted: Sat Sep 15, 2012 9:47 pm
hey i just recently come back from a 6000 km trip up to cape york and back to brisbane, all went well as i was able to drive back.....
how ever on my way up i engaged 4wd and noticed a slight grinding noise i can only imagine is comeing from the front diff, since continuing to keep driving the car to complete my trip the noise has become louder though it doen't seem to affect anything????? i changed the gear oils in the diffs before i left as the car had done 7500km and wanted to change the factory oil to remove any metal debris from the factory which there was quite a bit the oil was dis coloured and the magnet had a fair bit of shavings on it.... since i returned and during the trip i checked the front diff and the oil looks great no filings and definitly not a sign of water...
was really hoping someone might know what the noise is?
i also fitted a jb lift kit before i left and had a 1" prop shaft spacer machined and fitted on the transfer case end of the front prop shaft would any of these things maybe be to blame?
Post Posted: Mon Sep 17, 2012 12:28 pm
Do you really need the spacer with the lift? Most lift you don't need a spacer. Especially 1"
Pullout your front shaft and check the uni's. They can seize and cause vibration.
Post Posted: Tue Sep 18, 2012 3:39 am
apperently due to the castor corrected radius arms the spacer is nececary,
ill check the uni its something i have not looked at yet
also after taking of the noisy mud terrain and putting road tyres back on the noise more sounds like its coming from further back maybe t/c? i removed the spacer as well thought maybe if it were not balanced it could be the cause
the noise appears when engaging 4x4 and also when you take the foot off the accelerator, while accelerating the noise is gone??
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Tue Sep 18, 2012 6:52 am
Hmmm I have a JB 3" lift fitted in 98 Jimny with all the fruit and no prop spacer, I do have one sitting in my garage but never fitted it. Haven't had a problem with tailshaft pulling out as yet. I do have loads of whines and grinds etc from transfer and gearbox etc but put that down to wear and tear as car has done well over 300k
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Sep 18, 2012 1:21 pm
Transfer case mounts in good order?
Post Posted: Wed Sep 19, 2012 6:14 pm
yea all the mounts seem fine
ill leave the spacer out if it dosn't need to be there.
its a shame bout the noises since the car only done 15000klm and 3 months old it all still works just thought things would last longer
maybe its just a good excuse to replace the t/c with a sierra wt one with gearing sooner than i had planned :)
Post Posted: Wed Sep 19, 2012 7:27 pm
Hubs?
Post Posted: Wed Sep 19, 2012 7:34 pm
Take it in and get it looked at under warranty then... Just take the spacer out first ;)
Post Posted: Thu Sep 20, 2012 6:08 pm
that was the first thing i did but the dealer wants nothing to do with it, cause quote "suzuki doesn't like modified vehicles" hence why i thought i would try here before i take it to a mechanic and pay for an opinion
and yes i took the spacer out and the 235's m/t tyres off.... i left the suspension on though
and my back seat was not in either so they couldn't road test the car cause it was un road worthy
all good ill keep driving it with the whines and grinding noises, till it breaks what ever it is thats causing the noise... than ill know what it was :lol: just hope its not dangerous cant see why it would be
Post Posted: Thu Sep 20, 2012 6:19 pm
That's absolute bullshit! They can't tell you that it's in roadworthy because it has no back seats in it! Just the same as te noise is obviously a drivetrain problem (from what you've described) and has nothing to do with the suspension. The only thing that is void I warranty is your suspension... Because it doesn't exist!
Don't let them tell you otherwise!
Post Posted: Thu Sep 20, 2012 6:39 pm
i can kinda understand the back seat thing cause its registered as a 4 seater and only has two in it. but they were definatly trying everything not to touch it
and what you say bout the suspension warranty this is what i thought too.
the best bit is i took it for its 15000 k sevice while i was there for the warranty claim, and they changed oil and oil filter thats it!! the fluid in power steering needed topping up the air filter definaatly needed changing as i just drove 6000 ks through red bull dust etc it was filthy and still is, never road tested the vehicle etc all the things listed in the manual
ive contacted the service manager to complain but not getting very far
i want to keep winging but i really cant be f*cked and then they win! but i really not sure if i want them to be the ones that fix the car anyway, i would rather fix it my self so i know its done properly not half arsed like they service.
thats why i was after a few ideas as where to start, im quite capable of changing parts and servicing but not the greatest at diognosing the problems
Post Posted: Thu Sep 20, 2012 6:45 pm
Mate I had similar problems with the dealer I bought mine off... Try a different Suzuki dealer!
They can't knock you bak for having the rear seats out, just means no one can sit there!
Post Posted: Thu Sep 20, 2012 6:55 pm
yea thought i might try a different dealer
maybe i should spend the weekend returning it to stock than take it to a different dealer monday and see what they have to say
Vehicle: sierra
Post Posted: Thu Sep 20, 2012 6:57 pm
tell them to look at it or your going to fair trading and aca, also ring suzuki aust tell or qld depending on where you are tell them the dealer the problems the lack of service etc.
dont let the pricks walk all over you
Users browsing this forum: No registered users and 74 guests
