It is currently Mon Jun 29, 2026 11:17 am
Post Posted: Thu Sep 20, 2012 7:26 pm
Hit up some water crossings. long story short starter died ripped it out
It was full of mud and every thing u could think of.. Lol so got a brand new
One and it's still doing the same thing just ticks once when I try..??? But it
Does run if I clutch start it ...
Any ideas please help I want to go hunting lol
Vehicle: sierra
Post Posted: Thu Sep 20, 2012 7:33 pm
get a multi meter, check your batt voltage, should be between 12 and 13v if not charge your batt.
check your alti, its prob full of shit to.
Post Posted: Thu Sep 20, 2012 7:43 pm
Tried a new batt with jumper leads as well would that rule that out
Thanks
Vehicle: sierra
Post Posted: Thu Sep 20, 2012 7:49 pm
check your getting a neutral (earth) on your starter, also check you put the positive on the back of the new starter on the right pin.
Post Posted: Thu Sep 20, 2012 7:54 pm
It's back the same way I pulled it out?. But could be dirty earth under the bolt I guess I will try that thanks
Post Posted: Thu Sep 20, 2012 10:36 pm
If all else fails, try this viewtopic.php?f=5&t=14695&hilit=clicky+starter
Common problem
Post Posted: Fri Sep 21, 2012 7:42 pm
Thanks that worked heaps good..
But now the car won't fing idle or rev an till I hold it flat out
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Fri Sep 21, 2012 8:33 pm
U went through a water crossing. Electricals and carburettors don't like water. Check your airfilter for wetness. Check all your leads,plugs, dizzy, etc etc. I'd also try a carby clean. Providing it is carby??
Post Posted: Fri Sep 21, 2012 8:48 pm
Yea it is nmh didn't go over the head light and I got towed back out
It's pissing me off could the craby be fucked? Or need a kit?
Users browsing this forum: Google [Bot] and 206 guests
